Sponsored by: Auxito
Antifreeze leak
Old Jul 11, 2020 | 12:42 PM
colorado_junkie's Avatar
colorado_junkie
Antifreeze leak
Hello folks,
Looking for help on a 2000 5.4L Triton engine. I found an antifreeze leak under my truck and had a hell of a time finding where it was coming from. I looked at the heater tubes running into the firewall and checked the freeze plugs. Both areas were dry. Also followed the tubes from the radiator as far as I could and found no leaks. Then I happened to catch some sun light reflecting off liquid on top of the block just under the alternator. BINGO. Photos below. I also noticed that the leak stops when the truck is shut off. I am looking for suggestions on what to investigate before I begin the trek of pulling everything apart. Thanks in advance for the help.
Old Jul 11, 2020 | 12:58 PM
ford390gashog's Avatar
ford390gashog
Time for a intake manifold replacement and gaskets.
Old Jul 11, 2020 | 02:16 PM
colorado_junkie
Yup, after you pointed that out I went to Youtube and watched some videos. You nailed it! The leak on my engine seems to be coming from the driver side at the front, just like the videos. Thanks, I appreciate it.
Old Jul 11, 2020 | 10:53 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/8...d-on-5-4l.html
Old Jul 12, 2020 | 12:35 AM
whateg01's Avatar
whateg01
It looks like you have the aluminum crossover tube. On mine, the plastic around the seal in the plastic manifold had broken away so there was no way to seal it up with just the o-ring. I ended up replacing the manifold.
Dave
Joshua Dishong
Dec 1, 2018 02:42 PM
2fifty
Oct 29, 2017 09:01 AM
scottf4444
Dec 27, 2009 11:05 PM
Ranger88Den
Jun 29, 2005 09:45 PM
Rocking M
Dec 29, 2003 09:51 PM
