firing order
Old Oct 19, 2003 | 12:35 PM
ihatefords's Avatar
ihatefords
firing order
in what order do i put plug wires on the cap for my 93 4.0 inline six? clockwise or counter clockwise...... no clue.. trying to get running.
Old Oct 19, 2003 | 01:51 PM
StrangeRanger's Avatar
StrangeRanger
Firing order is: 1-5-3-6-2-4
Rotation is CW
The location of #1 is critical on a PIP distributor, it SHOULD be marked on the cap. If it is not, the electronics pigtail comes out of the distributor immediately beneath post #4. Post #1 is the one just to the front of it.
Old Oct 19, 2003 | 07:14 PM
ihatefords's Avatar
ihatefords
thx strangeranger.
got it running finally. what does pip mean.
Old Oct 19, 2003 | 07:59 PM
68torino's Avatar
68torino
ihatefords
Just curious, but is that the handle you want to use on a Ford site?
Old Oct 19, 2003 | 11:11 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Yeah what's the deal buddy?
Redneck-Cowboy
Old Oct 20, 2003 | 04:55 AM
ihatefords's Avatar
ihatefords
what took so long? i have had many fords. currently have 2. every hsndle i tried was taken , so i figured ford site that one has surely got to be available.
and what is a pip dist?
Old Oct 20, 2003 | 08:45 AM
cdherman's Avatar
cdherman
Cute --- now fill in your signature with that explaination for the "ihatefords" name so you don't get cr*p forever!
I don't know what PIP stands for either, but curious......
Old Oct 20, 2003 | 09:45 AM
armyguy's Avatar
armyguy
4.0 you mean 4.9 right
firing order is 153624 rule of thumb 15 to young
36 to old
24 just right
Old Oct 20, 2003 | 12:12 PM
StrangeRanger
PIP = profile ignition pickup. Ford's acronym for the distributor with the crank position sensor built into it.
Old Oct 20, 2003 | 04:25 PM
ihatefords's Avatar
ihatefords
yes i did mean 4.9. my bad. thank you for filling me in on the pip question. got her runnin, but is chuggin when drivin in every gear. have everything in it's proper place. 15 too young 36 too old 24 just right.(good one). unhooked egr(plugged vacuum line) ran better for awhile but doin it again. new cap rotor plugs wires and ignition module. can hear some sort of ticking but not sure if it's from any of the above mentioned parts. no plug wires touching. any suggestions would be great. besides changin my handle.......hehehehe
Old Oct 27, 2003 | 08:20 AM
Walking_Tall_0403's Avatar
Walking_Tall_0403
timing may be off a few degrees (it will still run)\
A lil trick until you can get a timing light on it, Loose the distributor assembly until it turns (but not to loose, just so it it is snug) and turn it until it runs smoother then tighten it back up
Murph2006
Jan 27, 2008 10:08 PM
JBG Bronco
Dec 15, 2007 11:58 PM
rwoodfin
Jan 28, 2003 06:55 PM
rywegh
17
Jun 5, 2002 08:43 PM
bigdeals
Bronco II
Jun 4, 2001 05:02 PM
