Losing the war on flash rust
Old Jul 10, 2020 | 11:27 AM
Itsmyford's Avatar
Itsmyford
Greetings gang. Still working on the 61 flareside. Trying to do a little body work/painting on my own. I decided tackle the tailgate first since it seemed less complex. Here is the scenario. I used aircraft stripper in attempt to remove existing paint, which was way less than effective. I followed that up with media blasting back to bare metal. I then scuffed entire thing with red scotchbrite pad which left it smooth and shiny. Next I treated twice with ospho to convert any rust. Wash, rinse and repeat. After that I thoroughly washed with degreaser, rinse and toweled dry. Lastly I blew entire thing off with compressed air.. Before I was able to return from my shop with acetone for final wipedown, my tailgate was covered in a bright orange haze. Flash rust. Wiping it down leaves a clean rag orange. I am hesitant to wipe down with acetone, much less mix up epoxy primer to shoot the piece. What am I doing wrong? Any and all advice would be greatly appreciated. Tim
Old Jul 10, 2020 | 11:32 AM
ford390gashog's Avatar
ford390gashog
Need to use a flash inhibitor. Lots of options out there https://www.eastwood.com/ew-after-bl...waAr5UEALw_wcB
Old Jul 10, 2020 | 11:35 AM
Itsmyford's Avatar
Itsmyford
I meant to attach this
Old Jul 10, 2020 | 07:25 PM
Marten's Avatar
Marten
You use a different process then me but............ What I did was strip to bare metal, wash with metal prep and rinse with water. It did the same thing. I then sanded it with 120 to remove it and primered away. No problem at all. I asked the guy that sold me the stuff and he says that is normal, nothing to worry about. Then he used some big words that I don't remember and would never be able to spell anyway.
Old Jul 13, 2020 | 11:07 AM
Itsmyford's Avatar
Itsmyford
Thanks to both of you. Looking forward to getting along with the priming.
buckeyebronco
Paint & Bodywork
Apr 28, 2010 02:57 PM
whitebassbenny
Paint & Bodywork
Feb 8, 2008 12:21 PM
BowTieHatr
1978 - 1996 Big Bronco
Apr 22, 2006 06:34 PM
wresleu
1997 - 2003 F150
Dec 13, 2005 09:25 PM
irondragon79
Jan 19, 2004 08:50 AM
