F350, 6.7 powerstroke. Currently stranded in Clinton NJ. This is an emergency as he has all his belongings and is in the middle of a move. Is anyone available to call him to troubleshoot his issues? Driving on highway in the heat, shifting stopped working. Got some error code for fuel pump, which is replaced and still not working. PLEASE HELP!
This is pretty vague, can you update the post with a bit more info, what error code he has, symptoms, etc. This will help people to know whether they have possible advice.
So there were no actual codes coming out using the code reader, but on his dash it stated "low fuel pressure." After he did research on that, he replaced both fuel filters and the in-line low side fuel pump. It is still saying "Low Fuel Pressure" on the dash, no codes are coming up. The truck will start, but then shuts off and does not run.
He's asking in the wrong place. Its not like anyone's life is in danger. Call the tow truck, tow to Ford dealer, get it fixed and move on. MIght have to pay someone to haul his stuff somewhere for him. But no one is going to die....
