1952 vent window pivot:
Old Jul 8, 2020 | 06:53 AM
leonharu's Avatar
leonharu
On the vent window post parts are there one or two of those thin shims.I have seen where there is two required.One below the tear drop and then another above the thick collar?I have taken several of these apart and found different set ups.I am just wondering exactly what part these thin shims play in the pivot post anyway?I know there are a lot of threads on this issue.
Old Jul 9, 2020 | 10:49 AM
joezzz's Avatar
joezzz
Vent window shims
to my best recollection, those shims make up for any tolerance differences between the window and frame, and provide a "flat' pivoting/rotational area between the window's frame and door frame & gasket.
Old Jul 9, 2020 | 07:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I saved these pics from one of the past threads, not sure which one. This arrangement makes sense to me, except that I think the brass shim should go above the thick round spacer, to reduce friction. Putting one brass shim above the round spacer, and one below the teardrop, sure couldn't hurt anything. (The screwdriver in the one pic represents the bottom of the window frame)
Old Jul 9, 2020 | 09:16 PM
abe's Avatar
abe
these are pictures of my vent pivots from my 55. Are they the same as 48-52? I hope they help.
Old Jul 9, 2020 | 09:22 PM
abe's Avatar
abe
More pictures
Old Jul 9, 2020 | 11:23 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Found these pics of the order of assembly on one of my old posts.
https://cimg5.ibsrv.net/gimg/www.for...e56bf7d05a.jpg
https://cimg5.ibsrv.net/gimg/www.for...53be575381.jpg
Old Jul 10, 2020 | 06:48 AM
big job's Avatar
big job
I did mine yesterday passenger side. My luck, already lost the brass shims and I do this kind of work with cardboard on the floor and still things grow legs? Anyways I don't see any effects with or with out them. And then this hasn't been opened in 50 yrs...
Old Jul 10, 2020 | 07:48 AM
leonharu's Avatar
leonharu
Abe,I think yours may be different than 1948-1952.After the tear drop mine had a thin shim then a thick collar washer before the spring.
Old Jul 10, 2020 | 09:04 AM
TitusDH's Avatar
TitusDH
OMG, I had forgotten all about it. And I did mine only 1 year ago, last summer....
Yours all look pristine compared to what I had to work with, this I remember clearly.
'77F250C
Mar 16, 2020 09:48 PM
beartracks
Jun 30, 2015 05:27 PM
SuperSnake
16
Aug 21, 2008 09:56 AM
