Sponsored by: Real Truck
Imported 2003 F350
Old Jul 8, 2020 | 06:15 AM
Wiggen's Avatar
Wiggen
4wd Low
Exclamation Imported 2003 F350
Hi! Please direct me to the correct sub forum if this is not the right place!
The truck i own today was imported from the states or canada in 2003. The original equipment papers are non existent so i am searching for a place where i can search or contact a dealer in states or canada regarding my truck's original equipment.
The truck was originally delivered with marking lights on the top cab. Now here in Norway those things are illegal unless i can prove to the right folks that it was original from the manufactor.
If you know someone or somewhere please reply!
Thanks in advance,
Wiggen,
Old Jul 8, 2020 | 08:03 AM
crewzer's Avatar
crewzer
Wiggen,
Cars and trucks sold in the US come with a Monroney Label (aka “window sticker”) attached to the inside of one window. Ford USA may be able to provide you a copy of the original — for a small fee, of course.
Another option might be to try this website linked below. Either way, you’ll need your truck’s Vehicle Identification Number (VIN).
https://monroneylabels.com/
Hope this helps!
Jim / crewzer
Old Jul 9, 2020 | 12:00 AM
Mello Yellow's Avatar
Mello Yellow
From a 2003 F350 sales advertisement....
Old Jul 9, 2020 | 06:42 AM
crewzer's Avatar
crewzer
^ This brings up what may be an important point. Roof clearance lights are standard on an F350 with dual rear wheels, as shown in the picture above. The clearance lights are a factory option on F250s and F350s with single rear wheels.
One way to show your local authorities that the five clearance lights are original equipment is to remove one for inspection. The mounting holes are clearly punched and painted at the factory rather than aftermarket.
Hope this helps!
Jim / crewzer
Old Jul 13, 2020 | 01:51 PM
Wiggen's Avatar
Wiggen
4wd Low
Even if i show or remove a light it wont matter, I need the actual papers on it. Its a struggle and pain in Norway.
Old Jul 13, 2020 | 01:57 PM
Just Strokin's Avatar
Just Strokin
What is the Truck VIN?
Old Jul 13, 2020 | 01:58 PM
Wiggen's Avatar
Wiggen
4wd Low
Old Jul 13, 2020 | 02:19 PM
Just Strokin
Here is the ETIS info from Ford. Hopefully they will accept it.
If you check towards the end of the PDF, you will see roof marker/clearance lights. This ETIS report is a build sheet for your truck.
File Type: pdf
Old Jul 13, 2020 | 02:35 PM
Wiggen's Avatar
Wiggen
4wd Low
Larry! You are amazing! Thank you so much for this!
This is EXACTLY what i need !!!
Old Jul 13, 2020 | 02:47 PM
Just Strokin
Glad could help.
Appears from the ETIS info, the truck was an export and sold in Europe? It states for export, KPH should be the outer ring on the speedo and not MPH, uses low sulfur (LSD not ULSD) and no catalytic convertor (no clean emissions) maybe?
Robbie V
Mar 21, 2012 10:24 PM
brknfrd
May 26, 2002 11:05 AM
