Very sensitive throttle taking off
Old Jul 6, 2020 | 08:32 PM
v84960's Avatar
v84960
Hi all,
I've noticed something that seems to be related to the engine/trans tilting forward. Background: My '67 f100 2wd has a 390 with the column-shifted 3 speed manual. When letting off the clutch to get rolling, the engine/trans tilt forward very slightly, which pulls the throttle open. I know this because I removed the hood and drove the truck with a buddy hanging out the window watching the air cleaner. The problem was much worse before I replaced the transmission mount, as there was more movement. It was bad enough to cause the truck to lay rubber unintentionally. With the new mount it's not so bad, but it still happens. The mount is brand new, and passes the jack-the-rear-of-the-transmission-up test. No separation or significant movement when you do that. I have jacked up the engine as well, and there's no real raising up of either side of the engine then. At this point, I'm figuring that the rod-style throttle linkage is just hyper sensitive to engine movement because one end of the rod is hooked to the firewall. It seems a cable setup would completely eliminate this problem. Do the rest of you folks have this problem, or is there something weird going on with my particular truck?
Old Jul 6, 2020 | 09:48 PM
kenny nunez's Avatar
kenny nunez
Sensitive pedal
If the “trapeze “ linkage is still mounted it is not adjusted correctly. Most people convert to a cable style from a later model truck. Probably your best move.
Old Jul 6, 2020 | 10:18 PM
v84960's Avatar
v84960
There's just a rod sticking up kinda parallel to the firewall, apparently directly connected to the accelerator pedal. Hooked to that rod is another rod that goes from there straight forward to the throttle arm on the carburetor. What truck do I need parts from to convert, and what years of truck can they come from?
Old Jul 7, 2020 | 09:43 AM
kenny nunez
Throttle
All the trucks from 73 on have what you need.
Old Jul 7, 2020 | 07:38 PM
v84960's Avatar
v84960
Good deal, thank you again. I think a buddy has one of those that he won't need the linkage on, I'll go check it out.
v84960
Jun 22, 2020 06:40 PM
N.W.Ford
May 30, 2014 08:50 PM
stephano
1983 - 2012 Ranger & B-Series
13
Oct 23, 2010 07:53 AM
howardlr
May 15, 2002 07:51 AM
