Sponsored by: Real Truck
2008 350 steering problem
Old Jul 6, 2020 | 01:34 PM
CAT731's Avatar
CAT731
4wd Low
I have a 2008 f350 5.4 triton. The truck runs like a top and is in really good shape for its age but the last few weeks I’ve had this steering issue. It feels like when making a right turn, as I’m going through the turn it wants to keep going right. Almost like something is sticking. I have to fight it to get the wheel straight again then it wants to pull left. At highway speeds it seems to drive fine. Only an issue at lower speeds mostly on right turns. I just had it aligned and the front passenger lower tie rod end and ball joint replaced. It helped a little but still doing the same thing. Any ideas? Thanks in advance for any help! Also seems like it makes it worse when I have the tires rotated. Could this just be from uneven tire wear?
mileage is currently 167,000
Old Jul 6, 2020 | 05:11 PM
jeffreyzamrzla's Avatar
jeffreyzamrzla
Is your truck 4 wheel drive? If so, check the front axle knuckles. From there, could be tie rods, ball joints or even power steering issues. In mine, it was the right axle knuckle. Very strange when you want to go one way and your truck says nope I wanna go here.
CAT731
Apr 26, 2019 09:27 PM
Mitch1407
Jul 30, 2011 11:47 AM
AllMuscle03
May 6, 2010 02:18 PM
xjcamaro89
2004 - 2008 F150
20
Jul 12, 2009 06:20 PM
PSDJOE
Jul 14, 2004 08:27 AM
