Cold Hard Starting
Old Jul 6, 2020 | 11:58 AM
Chips2000's Avatar
Chips2000
Cold Hard Starting
I read somewhere there is an injector shim kit to help eliminate cold weather hard starting. Could someone provide a link? I have already replaced the solenoid, but still have the problem.
Thanks
Old Jul 6, 2020 | 04:37 PM
FinnishStroker's Avatar
FinnishStroker
https://www.ebay.com/itm/TWO-94-03-7...0AAOSwzY5djxJC
Glow plugs stays on up to 120 seconds,depending on temps.
Nevermind the glow plug light,watch volt meter or do a GP led mod.
Glow plugs condition?
Ohmed out?
Old Jul 6, 2020 | 06:20 PM
Chips2000's Avatar
Chips2000
OK, thank you!
Old Jul 7, 2020 | 08:31 AM
Listor's Avatar
Listor
Thanks
HAve you checked your o rings, replacing mine cured my cold start issue, LOL well i will find out come winter, but it cured my long crank issues
i still have my shim kit sitting on the shelf, may still do it just to quite down the injectors
Old Jul 7, 2020 | 11:13 AM
Chips2000's Avatar
Chips2000
I will check the o rings.
I go to the mountains camping during the summer and that is where I have problems with cold starts. I learned to plug the heater into my generator and then starts are easy. In the winter, living in the desert, temps rarely get low enough to cause problems, but sometimes on the coldest days, I just plug the truck into the house circuit.
Old Jul 7, 2020 | 12:21 PM
AllaboutMPG's Avatar
AllaboutMPG
You may want to make sure everything in your glow plug system is working. Here's a good trouble shooting guide
https://sites.google.com/site/woodnt...ow-plug-system
Old Jul 7, 2020 | 12:45 PM
Chips2000's Avatar
Chips2000
OK, thanks!
Cliffhucker
Mar 12, 2007 01:47 PM
shaper
2004 - 2008 F150
Jan 29, 2005 11:56 AM
drgracdad
1978 - 1996 Big Bronco
Jan 13, 2004 11:10 AM
