cold starting proablem
Old Jan 11, 2005 | 06:11 AM
shaper's Avatar
shaper
Has anyone had trouble starting in cold weather,25 or so degrees?.When I try starting it first thing in the morning it goes in the failsafe mode.After a few trys it will start and run normal.Dealer says it is bad computer(pcm) and have one on ordrer.
Thanks for any info.
Old Jan 11, 2005 | 06:30 AM
Birdhunter1's Avatar
Birdhunter1
Haven't had a problem at all with mine, except a paint problem that is currently being taken care of. Good to hear that they are already taking care of you though.
Old Jan 23, 2005 | 12:56 PM
dicass's Avatar
dicass
Starting problem
I have a friend who told me today on her new 150 that when temp below 35 here in west Texas, it takes her 10 min or so to start up. It starts then dies and over again until it runs. in the shop now 3 times.
Old Jan 23, 2005 | 01:24 PM
Cavedave's Avatar
Cavedave
I've had no problems starting in cold weather including temps in the negatives. Turns over the first time.
Old Jan 23, 2005 | 03:27 PM
PaGe1's Avatar
PaGe1
Cold In MN
Living in MN the past 2 weeks it was bellow 0 degrees and i have not problems. It has a sort high pitch sqweel for 5 - 10 sec and then all is good!!
Old Jan 23, 2005 | 03:58 PM
ctfordguy's Avatar
ctfordguy
Been cold here in CT as well, around 5 degrees. No problems starting.
Old Jan 23, 2005 | 05:24 PM
shaper's Avatar
shaper
Dealer installed new pcm (computer) and replaced throttlebody.I have no more problems.Got down to 3 degrees when I was in Kansas on buisness and started fine.
Also seems to have a little more zip now than before,mabey the new pcm.
Old Jan 28, 2005 | 08:18 PM
Guido37's Avatar
Guido37
It was -25 here this morning and my 2004 XLT SCREW witn 11,500 miles would not start. Monday morning it was -24 and it just barely caught. Kicked a couple of times this morning but no go. Took my wife's Blazer to work (started right up) and called her later to try and start it. She said it started fine. Got home and tried it and again started fine, but noticed the check engine icon is on steady. Probably sensed something was wrong from this morning's attempt. I can see a block heater in my future.
Old Jan 29, 2005 | 04:31 AM
PC Poppy's Avatar
PC Poppy
According to my dealer, there are some issues with some of the starters Ford put in. They are a new type of starter and may have some water in them. At extreme cold temps they freeze and can't turn over fast enough. Don't put it off, go to your dealer and have him check it out when the weather is real cold. They have a service bulletin on it. I have had mine replaced with an upgraded type.
Old Jan 29, 2005 | 11:56 AM
bdmcdonald's Avatar
bdmcdonald
Last week it was -35C here and the truck starts great. The only thing is the fan belt squeal, which will be replaced at my next service. There is a TSB for the fan belt noise..
ejkoz
1997 - 2003 F150
Jan 26, 2010 05:26 PM
Big Dually
Modular V10 (6.8l)
18
Jan 6, 2003 08:40 PM
winfordr
May 20, 2002 09:14 PM
bigfordman70
1978 - 1996 Big Bronco
May 27, 2001 11:30 AM
