Steering Box recommendations
Old Jul 4, 2020 | 07:36 PM
fordtruckrodder's Avatar
fordtruckrodder
I am currently doing an oil cooler swap along with adding a coolant filter. While I have the truck apart I would like to replace the original steering box. I have been thinking about using the redhead unit, but from what i am reading it seems like their quality is slipping. I know the aftermarket, autozone, units have a better warranty then most, but I don't want to have to replace it once a year and really want something that I can install and not have to worry about. Any recommendations?
Old Jul 4, 2020 | 09:24 PM
2006powerstroke90's Avatar
2006powerstroke90
Autozone warranty is great. If you want to do the job every 6 months. I haven’t really heard anything bad about the redtop or blue top.
what’s wrong with yours now?
on my 03 I thought i needed a new steering box as well. I “tightened” it up and it made a world of difference.
Old Jul 5, 2020 | 04:16 AM
Yahiko's Avatar
Yahiko
I did the one in the truck I am now driving and went with the Ford reman unit.
I am quite happy with it.
One heads up. You will need a place to mount the box to so you can torque the
pitman arm nut down as there is not enough room to do it in the truck if you have 4WD.
Also be sure to flush the cooler and clean the reservoir. The hydroboost will hold some
fluid so you need to stick a hose on the return and step on the brakes to bleed out the
accumulator.You can also leave the hose on and once you have the engine running
step on the brakes again and it will dump anything left in it and once you see the fresh
fluid plus a few more peddle cycles you will have that flushed. That way you can start
out with a clean system.
Also get a new pitman arm nut as that is a use once and toss item.
Old Jul 5, 2020 | 08:40 AM
fordtruckrodder
It has a lot of play in it and the truck has 355k on it so wasn't sure if adjusting it would help any. What is the procedure for adjusting it, maybe I can give it a try?
Old Jul 5, 2020 | 09:00 AM
F350 1990's Avatar
F350 1990
Adjustment likely won't help with that mileage -- but you can give it a try (use a quality torque wrench).
As for reman/new ---avoid AUTOMOAN, avoid DEADHEAD, go with Moto.
Old Jul 5, 2020 | 10:31 AM
Yahiko's Avatar
Yahiko
One thing to keep in mind with Ford when they do a reman they put in new parts.
Look up broken sector shaft with the search tool. Red head reuses old shafts.
I am not sure about other vendors. The big reason I went with Ford was that
I had broken teeth on the shaft or the piston. I did not dig into it to find out.
Ford gave me full core charge back for it.
Old Jul 5, 2020 | 11:40 AM
TooManyToys.'s Avatar
TooManyToys.
I agree with Sean, for me, it would be Ford reman, BlueTop, or salvage a newer stronger box and adapt, not necessarily in that order.
Old Jul 5, 2020 | 08:59 PM
fordtruckrodder
Thanks. I will look into the ford reman or the blue top. Right now it would be delivery on either I have the truck torn apart. Is your reman still holding up well? How many miles do you have on it now? Replaced oil cooler and thermostat today and need to get it back together. I took out the radiator battery and just about all the obstructions the box is real easy to get to at the moment.
Old Jul 5, 2020 | 10:00 PM
Yahiko's Avatar
Yahiko
I think I did the steering gear about 2 1/2 years ago. Still nice and tight. I had looked into the swap
of the newer gear and I just did not want to do all the work to modify the truck to support the new gear.
I did do a heavy flush and cleaned the reservoir as it was nasty looking. I also put a filter into the system.
Old Jul 6, 2020 | 09:31 AM
TooManyToys.
And it's not inexpensive for all the parts.
Old Jul 7, 2020 | 11:28 AM
fordtruckrodder
Ordered the reman from Ford, will be in tomorrow. What should the pitman arm nut be torqued to?
Old Jul 7, 2020 | 05:09 PM
Yahiko's Avatar
Yahiko
Here is the info from the 2004 Workshop manual.
You must use a vise to install the nut as you can't do it installed in the truck.
At least on the 4WD there is no room to get at it.
Old Jul 8, 2020 | 06:07 AM
fordtruckrodder
Am I reading this correctly the sector shaft arm nut needs to be torqued to 23 LB FT? I would have thought it would have been much more than that.
Old Jul 8, 2020 | 07:23 AM
TooManyToys.
That's for the jam nut of the adjusting screw that nobody should be touching without the right tools, but do.
Third pdf that Sean provided.
Old Jul 8, 2020 | 08:22 AM
fordtruckrodder
i see, that looks closer to what i was thinking. Thanks for the clarification.
