Hate to ask this
Old Jul 4, 2020 | 10:57 AM
ynot321AB1's Avatar
ynot321AB1
So if I disconnect the fuel line from the pump to the carb and it is pumping fuel the cam is OK????
Old Jul 4, 2020 | 11:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Take the distributor cap off, it only takes 10 seconds. The fuel pump is a 1/2-hour job.
Old Jul 4, 2020 | 11:17 AM
Ken's 39er's Avatar
Ken's 39er
I had this same compression check problem years ago. The screw in compression gauge has a schrader valve that broke / wore out and would not hold the gauge pressure reading. On compression stroke the pressure would go up and then blead to "0". If you are cranking the engine using the key in the cab, the gauge will blead to 0 before you can look under the hood at the gauge. To test the gauge, watch gauge while cranking engine from under the hood.
Old Jul 4, 2020 | 11:34 AM
ynot321AB1's Avatar
ynot321AB1
It finally stopped raining long enough to find that the distributor is turning and fuel pump is pumping
Old Jul 4, 2020 | 11:37 AM
ynot321AB1's Avatar
ynot321AB1
Compression gauge is supposedly new of course with all this stuff made in China or Japan one can never tell
Old Jul 4, 2020 | 12:05 PM
Steve's Avatar
Steve
Maybe your new battery is turning the engine over so fast it just sounds like an LSD flashback. If the cam is turning the valves are working too. The question posed earlier was never answered. Was this engine running before the battery swap? If so, given what we know, there would be no reason for the compression to go away. It would help to post a video of the cranking ceremony.
Old Jul 4, 2020 | 12:07 PM
Ken's 39er's Avatar
Ken's 39er
Sounds like the engine internals are turning. Have you removed all of the spark plugs as advised in an earlier reply? Crank engine from under the hood while holding your thumb over the spark plug hole and feel the compression in each cylinder. Evan as little as 15 - 20 lbs pressure should record on the compression gauge. Can you test compression gauge on lawn mower, chain saw or another vehicle to verify it is working correctly?
Old Jul 4, 2020 | 12:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by Steve
... If the cam is turning the valves are working too. ....
It is common for flathead valves to get stuck open after periods of inactivity. For at least one on each cylinder to stick at once, seems unlikely but looking thru the plug holes to see if they are moving would verify.
Thumb over the plug holes would be a quick check on compression.
Old Jul 4, 2020 | 01:50 PM
ynot321AB1's Avatar
ynot321AB1
Great suggestion, will check compression gauge on lawn mower tomorrow. Have to get other things done before then.
ben73058
Dec 10, 2016 04:29 PM
hillcountryflt
Oct 10, 2014 08:50 AM
mOROTBREATH
Aug 29, 2010 09:37 PM
nsaikia
30
Jul 16, 2007 07:17 PM
1969FordF250
13
Apr 20, 2004 07:36 PM
