free to me,yeah
Old Jul 1, 2020 | 10:57 PM
dremtofford's Avatar
dremtofford
free to me,yeah
i was given a 1986 Fleetwood motor home that was built on an e350 chassis. the only problem i have is the neutral safety switch and the fuel pump. i bypassed the neutral switch to get it home but the aftermarket fuel pumps died thank God it was flat or downhill most of the way home. got it home and found out the fuel pumps in the back had died. tried to look it up online but i was told there are two fuel pumps, one the engine, and one in the tank. i could not find one on the engine and both in the back died and i haven't dropped the tank to see if there is one in there. i also need to get two batteries because i had to give the old ones back to my father. where do i find a book on this motor home? Fleetwood says to go to ford and ford says to go to Fleetwood. is this the right forum?
Old Jul 2, 2020 | 08:05 AM
wiskeyVI's Avatar
wiskeyVI
As far as books, you may just need to use one for that year van then general searches for motorhome issues.
Dies it have multiple gas tanks??
Old Jul 2, 2020 | 10:42 AM
dremtofford
yes it does have two tanks and they wired a toggle switch that is hooked directly to the battery.
Old Jul 2, 2020 | 05:09 PM
wiskeyVI's Avatar
wiskeyVI
I recall on older Ford trucks, that sometimes they ran off one external pump and had a manual valve, on the driver side seat mount area and you would switch from one pump to the other.
Old Jul 2, 2020 | 06:37 PM
Spaznaut's Avatar
Spaznaut
If you have 2 in the tank and your fuel injected then there is one after the selector switch on the frame rail I'd bet.
Old Jul 3, 2020 | 12:14 PM
wiskeyVI's Avatar
wiskeyVI
Man, are they fuel injected back then?
Old Jul 4, 2020 | 02:25 PM
Spaznaut's Avatar
Spaznaut
I had an '88 351w that was F.I. '86-'87 was the transition to FI I believe, depending on motor. Think '85 was for the cars.
DBrawley
18
Oct 27, 2009 09:54 PM
sacheeze
Jan 6, 2009 06:09 PM
Mike Gudgell
May 29, 2007 03:48 PM
gimmeice3
1978 - 1996 Big Bronco
Nov 9, 2006 09:14 PM
Mshell
Jun 15, 2004 08:21 PM
