Carb identification
Old Jul 1, 2020 | 04:46 PM
jason armistead's Avatar
jason armistead
Carb identification
Hey folks, I'm trying to find a Carter YFA for my '84 F150.
The part number is E4TE-9510-FA.
Mostly, I'd like to know what the the whole part number means so I can get an appropriate EGR valve to go with it.
The calibration number for the truck is 4-51H-R00.
Any help would be appreciated, as I'm pretty much in the dark on calibration code meaning.
Thanks
Old Jul 1, 2020 | 07:15 PM
Franklin2's Avatar
Franklin2
Your engine is all original? Everything is hooked up and working? All the vacuum lines are hooked up and all the wires to the sensors and the carb? If they are not all there, I would re-think buying a original carb or a EGR valve. It's computer controlled and if things are not hooked up, you are leaving lots of power and economy on the table. Sorry, just trying to look out for you and help you not waste any money. The engine you have can have lots of problems after it gets old and has been through several owners taking stuff off the engine.
Old Jul 1, 2020 | 08:36 PM
jason armistead
Hey Dave,
I'm the second owner after the Canadian Forestry Service.
I'm on the second engine, however, the computer works and all the other emission components check out.
I replaced the original carb once upon a time and even with the best tune ever, I can't get more than twenty miles to the gallon out of it whereas it used to average thirty.
I'm in the process of rewiring everything so I figured I might as well try to achieve that magic number.
I've got some time on my hands right now what with the pandemic.
Old Jul 1, 2020 | 09:21 PM
matthewq4b's Avatar
matthewq4b
Originally Posted by jason armistead
Hey Dave,
Without AOD https://www.rockauto.com/en/moreinfo...21432&jsn=2743
With AOD https://www.rockauto.com/en/moreinfo...21432&jsn=2744
If you are seeing a drop in fuel economy the most likely suspect is the O2 sensor.
Also, Ethanol fuel can have a big impact on fuel economy.
To be honest since nowhere in Canada is going to require you to have a tailpipe sniff you could just disable the feedback carb system and use an earlier carb you will pick up fuel economy and power to boot. I would not worry too much about the EGR valve they really almost never go bad unless they start leaking (Not sealing between intake and exhaust) or get plugged up.
And the EGR valve not functioning is not negatively going to impact fuel economy not having it functioning will actually improve it.
Old Jul 2, 2020 | 07:35 AM
Franklin2's Avatar
Franklin2
I am surprised it being a Canadian truck that it has the computer system at all. Some of the trucks up there didn't have it did they?
jzzzake
Jun 20, 2015 10:43 AM
lazzarruss
15
Oct 30, 2013 08:59 PM
BlackLabel78
Mar 3, 2010 03:31 PM
amstone
May 24, 2008 07:06 PM
