98 ranger dome light
Old Dec 17, 2010 | 08:51 PM
socalarcade's Avatar
socalarcade
is there a way to turn the dome light on from inside the dimmer switch does not do anything and there is no switch on the dome light .
Old Dec 17, 2010 | 09:12 PM
g_k50's Avatar
g_k50
rotate the dimmer switch. there's a stop that might be harder than you expect. I'm assuming the light works when you open the door? that's another way of turning it on but I assume it's not the one you are considering.
Old Dec 17, 2010 | 10:49 PM
socalarcade
its when you are in the truck . i will try the dimmer again maybe be broken
Old Dec 18, 2010 | 09:17 AM
03 Maz B23's Avatar
03 Maz B23
The reason light is staying on is the switch inside door (internally attached to door lock mechanism, can't see it from outside) is either dirty or defective. A good shot of WD40 or contact cleaner will usually fix the problem.
phillyken
Apr 2, 2016 09:44 PM
Peavey1986
Dec 20, 2015 07:11 PM
Heather Brummett
Sep 28, 2015 09:51 AM
socalarcade
Dec 12, 2010 05:17 PM
reamer
Oct 21, 2008 10:16 AM
