Sponsored by: Real Truck
Drive shaft slippage
Old Jun 26, 2020 | 12:09 PM
DESERT ED's Avatar
DESERT ED
Hey all...having problems trying to solve my rear drive shaft that slips a little bit on take off.
hit the gas and I can tell that it’s rotating... but it takes a second or two to engage and move. Any advice is welcome.
search only turns up a bearing vibrating... thTs not it. Thanks.
2014 f350 6.2 4:30
Old Jun 26, 2020 | 03:47 PM
Desert Don's Avatar
Desert Don
2014 f350 6.2 4:30
I don’t think there is anything to “slip” in a drive shaft for a second or two. U-joints would be gone, splines would be gone. There is nothing else.
Old Jun 26, 2020 | 03:55 PM
85e150's Avatar
85e150
A differential will do that, usually once and you have to be moving. If you have a toothless section of the ring gear, it's possible. The noise and jerking and eventual destruction of the axle would have happened by now.
As said above, the drive shaft really has no mechanism that could fail enough to slip. If it fails, it's done and on the ground, one end or the other.
Your transmission may be the culprit. Do you have any CEL showing?
You may wish to visit a Ford dealer, or someone who has the correct Ford code reader for transmissions, and have the codes checked.
Also, check the fluid for metal or other evidence of failure.
Good luck.
Old Jun 26, 2020 | 05:53 PM
galaxie112's Avatar
galaxie112
4wd Low
There is a phenomenon that Ford calls "driveshaft spline slip/bump". My 2012 f250 6.2 does it from time to time, it's a momentary issue just as you toe the throttle. What happens is the driveshaft changes length, just slightly, as the pinion angle changes and the splines slip by design. As a warranty at the dealer where I worked repair we used to remove and disassemble/lube the slip joint. As a practical fix I will go buy a pallet of wood pellet fuel ( 2,000 lbs.) and drive the truck energetically. This will exercise the spline and remove the slip/bump feeling.
Hope this might help.
Bill
Old Jun 26, 2020 | 11:19 PM
85e150's Avatar
85e150
IIRC this type of "bump" was happening with Toyota Tacoma's with a V6 and manual transmission. The rear axle starts to wind up, as they pretty much all do, but the splines don't want to slide. Finally they let go when the wind up and power overcome the static friction of the splines.
I noticed on mine they always included the driveshaft spline lube in every service. At least on paper. Mine was a 4 cylinder, so not much was happening wind up wise back there.
An easy fix with instant results. Good luck with it!
Old Jun 26, 2020 | 11:36 PM
yardbird's Avatar
yardbird
Wouldn't it be possible to drill and tap, then install a grease fitting on the outer shell of the driveshaft at the slip joint? Over the road big trucks all had then before everything became "permanently greased".
The lack of grease fittings was claimed to be an EPA thing, but I think it's because it's cheaper and easier to build without fittings.
Old Jun 27, 2020 | 09:05 PM
crusty old shellback's Avatar
Had a similar issue on one of my trucks.
wound up being the spider gears in the diff were wore out. There was a bunch of play in them.
mattymax
Jan 23, 2017 01:58 PM
sperober1
1997 - 2003 F150
Jul 1, 2014 06:47 PM
UP77F250
20
Apr 9, 2013 11:46 AM
96f150
1997 - 2003 F150
Aug 12, 2012 06:06 AM
bassaway
2004 - 2008 F150
Feb 21, 2009 07:05 AM
