Small block Ford timing cover interchange?
Old Jun 25, 2020 | 09:07 AM
tdmoparguy's Avatar
tdmoparguy
I have a 1997 351w roller motor that the timing cover is broken on, is a 1996-2001 Explorer 5.0 timing cover compatible or do I need one off of another roller 351w?
Old Jun 25, 2020 | 09:11 AM
GNR22's Avatar
GNR22
Timing cover should be the same on those two. The only difference between any of the timing covers is the direction that the pump rotates on V belt systems vs serpentine belt systems.
Old Jun 25, 2020 | 09:34 AM
tdmoparguy's Avatar
tdmoparguy
Awesome thank you.
Old Jul 1, 2020 | 06:55 AM
baddad457's Avatar
baddad457
No, they're two very different timing covers.
Old Jul 1, 2020 | 06:56 AM
baddad457's Avatar
baddad457
You're wrong. The Explorer motor used a completely different timing cover, it also was used on the 94-95 Mustangs. Water pumps are different as well.
Old Jul 1, 2020 | 07:24 AM
tdmoparguy's Avatar
tdmoparguy
So what is compatible?
Old Jul 1, 2020 | 08:21 AM
GNR22's Avatar
GNR22
Yeah I just googled the explorer timing cover. I assumed they used the same timing cover as every other serpentine 302. Ford and their infinite wisdom of one-off parts...
https://lmr.com/item/LRS-6019B/83-93...iABEgKopfD_BwE
This is the style of timing cover that the roller 351w would have came with.
Old Jul 1, 2020 | 10:08 AM
Conanski's Avatar
Conanski
There are a bunch of different timing covers available, ignoring those with a fuel pump boss for a second there are standard rotation and reverse rotation as well as a universal version, those with the crank sensor boss and those without, and those with a dipstick tube hole and those without. This diagram shows some of those and the last one down is the one I believe is needed here.
Old Jul 1, 2020 | 10:19 PM
baddad457's Avatar
baddad457
Yea, that's it. The top middle is the 94-95 Stang and 96-2001 Explorer/Mountaineer cover. If I'm not mistaken that was also used on the last year's T-Bird/Cougar too
Old Jul 1, 2020 | 10:21 PM
baddad457's Avatar
baddad457
You're looking for one from a 87-97 5.0 or 5.8 out of a pickup or van.
Old Jul 2, 2020 | 05:59 AM
tdmoparguy's Avatar
tdmoparguy
Right on, thank you.
Old Jul 2, 2020 | 06:09 AM
baddad457's Avatar
baddad457
This is for a Mustang, the pickups and vans used a different cover with the coolant ports reversed. See the pic Conanski posted with the various covers.
Old Jul 2, 2020 | 01:51 PM
diggerrigger's Avatar
diggerrigger
So, a 1986 5.0 truck is different from a 1987 5.0 truck?
Old Jul 2, 2020 | 02:30 PM
baddad457's Avatar
baddad457
They may be the same, I'm not 100%. Seems like 86 was the first year for the reversed cover though
Old Jul 2, 2020 | 03:51 PM
diggerrigger
I looked into this further. I think you were correct. My 1986 5.0 w/v-belt is the same as the'88 Crown Vic w/serpentine.
On the'86, E3AE left. E5AE right, on the Crown Vic
​​​​​​I think these two are interchangeable.
