Improved 5R110 3-5 shift
Old Jul 6, 2020 | 07:58 AM
  #31
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can also get the Ford shop manual at www.helminc.com
Old Jul 6, 2020 | 08:41 AM
  #32
MisterCMK's Avatar
MisterCMK
What are you looking for from the shop manual? I've got a printed set for the 2007 and I also have alldatadiy access for my 2007.
Old Jul 6, 2020 | 09:14 AM
  #33
Monster-4's Avatar
Monster-4
Need the troubleshooting tree for low WOT/stall pressure.
Old Jul 6, 2020 | 02:54 PM
  #34
MisterCMK's Avatar
MisterCMK
I'll see what I can dig up tonight
Old Jul 6, 2020 | 03:07 PM
  #35
Monster-4's Avatar
Monster-4
Thanks a bunch!
Old Jul 6, 2020 | 03:08 PM
  #36
TooManyToys.'s Avatar
TooManyToys.
If the 2003 info is the same I can throw that up, I just don't know if it is.
Old Jul 6, 2020 | 03:54 PM
  #37
Mark Kovalsky
It should be.
Old Jul 6, 2020 | 04:04 PM
  #38
Monster-4's Avatar
Monster-4
Originally Posted by Mark Kovalsky
It should be.
I'll take it! Thanks Jack and Mark!
Old Jul 6, 2020 | 04:41 PM
  #39
TooManyToys.
Going to be limited per post.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 6, 2020 | 04:46 PM
  #40
TooManyToys.
More to add ...
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 6, 2020 | 04:50 PM
  #41
TooManyToys.
The final 4.....
It will be interesting if the manual changes.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 6, 2020 | 08:28 PM
  #42
Monster-4's Avatar
Monster-4
Thanks a bunch Jack. Looking at some of the pinpoint/diagnostic trees I think I have three threads to chase. One is my original complaint of a slow 3-5 shift. Two is low drive WOT/Stall line pressure. Three is high idle and idle drive pressure. Looking at the charts mine seems to be almost double the values.
Old Jul 6, 2020 | 08:45 PM
  #43
Monster-4's Avatar
Monster-4
If I look through section 14 it seems issue 1 is 211 and 228, issue 2 and 3 is section 11. Looking at the guide I may have not performed the WOT test correctly. I pretty much gunned it and it says to slowly build up to WOT. Also I will need check the stall RPM speeds.
Old Jul 6, 2020 | 08:51 PM
  #44
TooManyToys.
Hope it helps. I wasn't trying to step on Chris's toes, I had it at the ready. The 2006/7 manual may have some updated info too.
Old Jul 8, 2020 | 04:52 PM
  #45
MisterCMK's Avatar
MisterCMK
No toes stepped on here! Glad you had it at your finger tips - summer is the busy season here at work so not as much time to search for stuff.
