Check engine light
Old Jun 21, 2020 | 08:37 PM
gregg kulpa's Avatar
gregg kulpa
Check engine light
Hey all i have a 2004 ford explore im getting a code of p0430. catalytic converter is it best for me to just buy another one or try and i can use to clean these. dont think i need to do the sensors as per the code any help with this?
Old Jun 23, 2020 | 08:59 AM
shorod's Avatar
shorod
This diagnostic code does not necessarily mean the bank 2 catalytic converter is bad. It could be caused by an oxygen sensor that is not reading correctly, but a misfire, or even by an exhaust manifold or manifold gasket leak. Have you performed any troubleshooting to confirm the converter is the issue?
-Rod
Old Jun 23, 2020 | 10:25 AM
gregg kulpa
well i know theres no misfire the truck does idea correctly and shifts in and outa gears fine, i drove it on the highway at 70 mph and it was mainly sluggish. after ia look over i did see the muffle will need to be replaced as per a few holes in it.
Old Jun 24, 2020 | 07:09 PM
gregg kulpa
Hey All quick update i check all plugs and wires checked the manifold the whole exhaust, No leaks all plugs are good, so i did do the heat test one the catalytic converters. drivers side i got like 320 degrees in and out was only like 240-250. passenger was about 320 and 215 -220. so not i believe its the cat. question is should i just do both cats or a whole exhaust?
Lucas Frink
1978 - 1996 Big Bronco
Jul 1, 2019 09:04 PM
jmacd27
Jul 6, 2005 07:47 AM
bkc1964
Dec 31, 2003 01:57 PM
JoggingGuy
1983 - 2012 Ranger & B-Series
Dec 10, 2003 05:02 PM
Raja2973
Jun 10, 2003 11:51 AM
