E4od help?
Old Jun 21, 2020 | 07:22 PM
jmtbiggin's Avatar
jmtbiggin
E4od help?
Resurrecting a 1991 E350. 7.3 idi, e4od. Carpenter made short bus. I purchased it with a bad tranny. The motor runs great and the transmission is rebuilt and works great. Had a dash mounted OD Button that was broke off when I bought it. I fished the pigtail out and put in a junkyard sourced OE button out of another e350. Test drive. OD will not cancel, no light on button either. Pigtail has 4(maybe 5, can't remember) wires. Internet search is full of dead ends. Any suggestions on how to make this rig lock out OD?
Old Jun 22, 2020 | 04:14 AM
JWA's Avatar
JWA
If you don't get the info you're seeking here try the transmission sub-forum as this might be an easy fix for those guys. Definitely mention you've posted this same question here so you're not re-directed back to here.
HTH
Old Jun 22, 2020 | 05:21 PM
jmtbiggin's Avatar
jmtbiggin
Thanks for the suggestion
dwrestle
Jan 5, 2010 09:42 AM
rick90yj
Jan 3, 2005 07:20 PM
Kikwear
1978 - 1996 Big Bronco
16
Feb 6, 2004 01:03 PM
