scary cr
Old Oct 18, 2003 | 05:42 PM
stratton's Avatar
stratton
scary cr
hey guys i've been building a 390for my work truck
have short block and parts ready for assembly
have a 68 360 block bored .040 over with silvolite 1130's
crane 343801 cam and rebuilt heads with mildly ported exhaust
390 crank and rods edelbrock performer intake and holley 650 cfm carb flowtech headers
i plugged my numbers into the compression ratio calculator and came up with almost 12 to 1
please tell me i missed something this is way to high i don't even know if it would run opinions?
also where can i order a new set of head bolts?
Old Oct 18, 2003 | 05:53 PM
Ratsmoker's Avatar
Ratsmoker
Welcome to FTE!!!
What is the compression height and dish(cc) for those pistons"? It takes domed pistons or a lot of shaving to make a 390 have 12:1 so yes you figured in something wrong somewhere. New head bolts can be ordered through www.summitracing.com for about $50. You should be able to get the stock cheapies at autozone for a little less.
Old Oct 18, 2003 | 06:23 PM
Ratsmoker's Avatar
Ratsmoker
I did some research and found your piston specs.
You have a 3.784" stroke. Divide this by two. (1.892). Add 6.488" for the rod length and 1.76 for the compression height. This will give you 10.14. The FE deck heighth is 10.17. This puts the piston .030 below the deck. The 1130 pistons have a 19cc dish to them. Your head gaskets have a 10cc displacement if you are using the standard felpros. Your heads displace about 67cc. This gives you roughly 8.95:1 compression with your 4.09 bore.
Old Oct 18, 2003 | 06:36 PM
Jarlaxle's Avatar
Jarlaxle
Any part store will have head bolts. If you're as paranoid as I am, order a set from ARP & never worry about them.
If ratsmoker's figuring is right (and I have no reason to think it isn't), that's just about perfect for a street engine--and should live happily on 89 octane gas.
Old Oct 18, 2003 | 06:45 PM
Ratsmoker's Avatar
Ratsmoker
I think I know where you messed up stratton. In most online compression calculators you need to enter the piston dish as -19cc not 19cc. Also the FE head gasket is not round so I just add 10.1cc to the chamber volume and enter the gasket thickness as .0001.
Old Oct 19, 2003 | 04:34 PM
FE427TP's Avatar
FE427TP
plus odds are the heads have bigger chambers than they were supposed to anyways unless you've cc'ed them it's probably safe to assume on the large side of their range
Old Oct 20, 2003 | 08:08 AM
stratton's Avatar
stratton
thanks alot guys i got a little flipped out there appreciate the help couldn't do this without fte
Old Oct 20, 2003 | 08:26 AM
William's Avatar
William
Excellent! Rat you are the man! I have this engine and it runs on 87 octane at 12 degrees initial advance. Rarely it will diesel a bit and sometimes it will kick aganst the starter. Really a good running street commuter engine. One thing I always do without ever compromising is to install ARP fasteners. I like studs for these old heads and use moly and torque them at the max recommendation. I sneak up on final torque go to 60 fp then 20 fp at a time until finally ending up at (gee I forget but it is a bunch)! Balance the rotating assembly, you will be happy for doing this.
Old Oct 20, 2003 | 08:29 AM
Ratsmoker's Avatar
Ratsmoker
Thanks and you are welcome! I wish I would have used head studs. I got the ARP bolts. I don't know what I was thinking. They don't cost any more than the regular bolts.
Old Oct 20, 2003 | 06:33 PM
FE427TP's Avatar
FE427TP
that you may want to remove the heads someday?
Old Oct 21, 2003 | 06:11 AM
William's Avatar
William
Head removal on an engine that used studs to mount the cylinder heads used to be a problem. That was before ARP came along. Their studs go in hand tight and can actually be installed with the head sitting on the block. Later when its time for head removal the ARP studs can be removed by hand and if they get sticky a little allen wrench can be used. With the ease of use and clamping pressure of studs verses bolts, I cannot understand why anyone would use bolts? The only issue I have encountered with ARP studs on FE motors is oil pan clearance on the number 5 main cap. In that case I use two ARP bolts and the rest studs. Fe's are so massive on the bottom I feel this small compromise is OKAY!
Old Oct 21, 2003 | 07:45 AM
Ratsmoker's Avatar
Ratsmoker
I covered my engine in a garbage bag and popped the number 5 stud ends through. I ground them flush with the nut. It worked great and stopped metal shavings from getting in the engine.
hotdotdog
May 12, 2013 02:26 PM
jazzy66
Feb 28, 2005 07:20 PM
Goodold71
Jul 28, 2003 02:04 PM
freejay
May 20, 2003 10:10 AM
ibski63
Sep 5, 2001 05:34 PM
