Rear view mirror
on
The basic mirror uses 3 wires or 2 if you don’t care about it un-dimming when you put it into reverse.
Basic Wiring is: switch 12v, ground, reverse and if you get one with temperature display it will have 2 more wires running to the sensor behind the grill which you will have to grab and add in.
Thanks for the info! I'll run the wires after I receive it this week and get my new windshield installed next week.
There is a plug for the factory mirror but it’s pretty inconvenient to get to, it’s on the A pillar post behind the dash and would require removing the ebrake, column and aluminum brace, not worth trying to get to.
Simplest would be hook ground up to a clean piece of metal and use an add a circuit to your fuse box on an ignition powered fuse.
on
on
Well - this is odd. I thought I would get one of the add a circuits that goes up to 10 amps and put a low amp fuse in it as the mirror pulls milliamps I believe.
Looking at the fuse diagram the Auxiliary Fuel Tank Selector seemed a good location. But when I opened the fuse box there is no fuse in that slot. Yet my dual tank selector works. Hmmm......I've owned this truck since '95 and I'm confident the PO did not mess with the wiring.
on
Yes. I'm going to use one of the other slots. Originally I misunderstood the ratings. I want the 10 amp rated wire so I get the smallest wire going out. I don't need a 10 ga. to 16/18/20 ga. (mirror wire) connection...
on
Project is complete. The Gentex GNTX-455 fitted onto my original wedge perfectly. It turns out that the Littlefuse 10 amp Add-A-Circuit also says not to power anything above 10 amps in either fuse slot (original fused circuit or new circuit), so the fuse holder is only rated combined 20 amps. I guess as the mirror only draws milliamps you could add a higher than 10 amp fused circuit in the original circuit slot. They do make a 20 amp version too.
I used the unused 10 amp slot that I described earlier that is ignition switch controlled. Works perfectly. Only put the mirror circuit fuse in it with a 3 amp fuse.
As mentioned it really modernizes the interior.The ground screw was right under the fuse box for a neat install. New windshield is coming on Tuesday.
Thanks for guidance!
Gentex GNTX-455 Auto Dimming With Compass
1991 F150 Fuse panel with Littelfuse Add-A-Circuit 10 amp model
Littelfuse 10 Amp Add-A-Circuit
#30
