Sponsored by: Kumho
instant right turn
Old Oct 18, 2003 | 04:00 PM
canbman's Avatar
canbman
Unhappy instant right turn
ok here's a good one for ya'll.last weekend I had a bit of a brain fart.I was driving mabey a lil too fast for the rainy conditions and as I went around a bend I hit a patch of standing water hydro plened did a 180 and hit the curb and up onto the median I went. now besides blowing the right side rear tire off the rim I obviously did some damage to the front end.I have since replaced the drag link and tie rod(link rod).when i start the engine the steering wheel instantly spins to full lock right hand turn.I'm lost as to the cause any help would be greatly appreciated.
Old Oct 18, 2003 | 04:41 PM
ctfuzzy's Avatar
ctfuzzy
Re: instant right turn
Divine Intervention.
If it ain't that you might want to see if there are any wires plugged into your steering box. If there is, major surgery is probably in your vehicle's future.
Old Oct 18, 2003 | 08:48 PM
rebocardo's Avatar
rebocardo
I know the full right lock can happened when the lines are not hooked up correctly and a few mechanics have badly broken their arms when they started the trucks by reaching through the steering wheel. Something Ford old timers warned me about.
I would guess you have probably broken your steering box, especially if you hit hard enough to bend a drag link, that takes some doing. You should check your frame (the back side inside the channel) and see if it is cracked, then jack up the truck again and see what happens in that area while turning the wheels back and forth with the truck OFF.
Old Oct 19, 2003 | 08:42 PM
xray1murphy's Avatar
xray1murphy
Sounds like you blew the pressure valve in your box, this will cause a surge of pressure to pressurize the box, spinning the wheel to one direction.
Old Oct 19, 2003 | 10:32 PM
canbman's Avatar
canbman
thanks for your help ill check the box
Highmark18
Oct 26, 2012 04:58 PM
forum155pl
Dec 14, 2010 11:12 PM
y0manda
Dec 6, 2009 01:18 PM
vantastic
Electrical Systems/Wiring
Aug 8, 2009 05:16 PM
FTE Ken
Site Announcements
Nov 18, 2000 02:54 PM
