Code P144C - Evap Purge Valve
Old Jun 17, 2020 | 07:37 PM
ThirdsACharm's Avatar
ThirdsACharm
Hi - I didnt see a lot of info on this code so just to help other ecoboost F150 owners of this generation...
At 127K miles, my '11 3.5 ecoboost got the CEL with code P144C - Evaporative Emission System Purge Check Valve Performance
I ordered this part: STANDARD MOTOR PRODUCTS CP932. I think the OEM part number is BL3Z9B325C
It sits on top of the engine just under the plastic cover. The swap required 1 8mm bolt removal and 3 hose clips.
It took me more time to park the truck in a way to best avoid the nosy neighbors from reporting me to the HOA than it did to swap it out
I'd say start to finish, it took 5 minutes.
I cleared the code and so far, so good.
Dont know how long the old valve was acting up before it threw a code, but it idles much more smoothly now.
Old Jan 14, 2023 | 05:43 PM
colguin29's Avatar
colguin29
1st Gear
P144C code 2014 3.5 EB
Where about is this part to replace it? Also can you provide a link to the one you used? I know this is old but a response would be much appreciated! Just had this come up on my 14 f150 3.5 EB. Thanks
RusPro
4 Cylinder Engines
Feb 11, 2017 10:00 PM
dvlsmstr
1997 - 2003 F150
Feb 2, 2014 06:57 AM
Anderson3476
Feb 9, 2013 11:12 PM
pablocruz69
Aug 13, 2010 12:50 PM
silvertp37
1997 - 2003 F150
Sep 7, 2008 11:01 AM
