Error code p1201
Old Feb 8, 2013 | 09:13 PM
Anderson3476's Avatar
Anderson3476
Error code p1201
I am getting an error code of 1201. Is this the ERG valve? How do I change out? Pictures or diagram would be appreciated.
Old Feb 8, 2013 | 10:12 PM
rla2005's Avatar
rla2005
None of my Ford Service Manuals or online sources show code P1201. What year/engine Ex do you have?
Old Feb 8, 2013 | 10:34 PM
Anderson3476
2000, V-10. Auto Zone is saying it is theEGR Valve Pressure Sensor.
Old Feb 8, 2013 | 10:53 PM
Stewart_H's Avatar
Stewart_H
Diagnostic Trouble Code (DTC) P1201: Cylinder #1 Injector Circ Open/Shorted
Are you sure you heard them correctly?
Double check that DTC code because that code number isn't related to the EGR.
Stewart
Old Feb 9, 2013 | 10:47 PM
Anderson3476
Re-pulled code....got different code p1401 which comes back to DPFE. Any suggestions on installation? Do I need to do anything with EGR Valve, cleaning etc?
Old Feb 9, 2013 | 11:12 PM
Stewart_H's Avatar
Stewart_H
P1401 Diff Pres Feedback EGR Circ High Input.
I did a quick search on FTE (all forums) using the search term "P1401" and got a lot of info.
I have zero experience regarding this code and your problem so I'd suggest you check out the same results I got by doing your own search.
Stewart
Dozeman
Apr 21, 2013 06:29 AM
