Please help with break lights
Old Jun 15, 2020 | 09:55 PM
NSAJMART's Avatar
NSAJMART
I have a 1968 Ford f250 Camper Special that I have taken apart and sanded it down and had it shot with epoxy primer. I'm putting it all back together now and am having a fit trying to get the break lights and tail lights to work. They all worked before I took them apart and I hooked them back up (just plug them in) and all I have working is the turn signals. I bought new bulbs too. I have power going to each unit. Any help would be greatly appreciated.
Thanks,
Joe
Old Jun 16, 2020 | 07:53 AM
Coastal68's Avatar
Coastal68
Try this thread: https://www.ford-trucks.com/forums/7...ng-1968-a.html
If you include this: site:www.ford-trucks.com in the search bar, google will pull up dozens of FTE threads on most of the common problems these trucks have. I have found many answers to my questions over the years this way.
Here's the google search that got me the thread I linked to above: https://www.google.com/search?q=brak...w=1280&bih=625
Old Jun 16, 2020 | 09:52 AM
davelj's Avatar
davelj
I would look real hard at my grounds. Those lights ground through the mounting surfaces so a coat of new primer could cause problems. Try a jumper wire from the mounting screws to the frame.
Old Jun 16, 2020 | 12:58 PM
sparky72's Avatar
sparky72
Yep, almost certainly a grounding problem if you have voltage at the socket but no light illumination.
Old Jun 16, 2020 | 03:41 PM
Lrrr-RulerOfOmicronP's Avatar
If the turn signals work I would test power at brake switch then verify the wiring in the column since the brake lights are ran through the column.
Good luck.
Old Jun 16, 2020 | 04:54 PM
NSAJMART's Avatar
NSAJMART
Thanks everyone. I appreciate the help and will attack the issue tonight
Old Jun 16, 2020 | 08:59 PM
NSAJMART's Avatar
NSAJMART
You were spot on davelj! I would never have thought the housing was the ground. Thanks again everyone!
tater3000
Oct 16, 2019 08:05 AM
Ewaldinger
Jun 11, 2017 02:28 PM
Pops05
Aug 2, 2015 05:53 PM
rescue947
1983 - 2012 Ranger & B-Series
15
Mar 16, 2013 06:34 AM
carolinaborn82
2004 - 2008 F150
Jun 25, 2012 11:17 PM
