Really, 142K ??
Old Jun 14, 2020 | 11:50 PM
Red Sonja's Avatar
Red Sonja
Really, 142K ??
OK, I decided that rather than completely rebuilding my 7.3, I would just purchase a "low" mileage engine off ebay. I chose a large diesel specialist recycler and found one with only 142K. However it was in BC, Canada, fine I can wait....
Well it got here and after unpacking, attaching to my engine stand, cleaning, cleaning, cleaning I began to strip it. I have found several things that make me doubt the seller's mileage claim and need opinions. I do have in writing that the compression's were: "All of them were within 5lb or 2%. Range low 380 and high 385". Unfortunately, it was too difficult to rig a starter to my engine stand and test those numbers before I actually get it into my F250 XLT (and then it's too late [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img] ) So here are the things on this engine that don't make sense for a 2002 with only 142K.
First, the amount and depth of rust. I don't know what they put on their roads in BC but this is MUCH worse than my '99 with 250K!! Here are just a few examples...
Oil pan
Exhaust manifold (really deep pitting)
Oil cooler (thought these were SS?)
Then when I got to the HPOP, I see that it is a reman? Is this reasonable for a 7.3 with only 142K?
Any and all opinions are welcome. Well other than, "you should have purchased a long block from ..." I checked into that route and it was beyond my budget.
Thanks from an old female mechanic (career as computer analyst, NASA and Siemens) on her first diesel adventure [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
Old Jun 15, 2020 | 06:40 AM
Ridedan2's Avatar
Ridedan2
Don’t know about the Reman HPOP. Honestly the pictures of rust look like what is expected from 20 years of salt driving. Mine looked similar, E99 with ~145,000 miles currently. I have since replaced everything rusted in your pictures and more.
Old Jun 15, 2020 | 07:21 AM
7.3Shortbus's Avatar
7.3Shortbus
My oil pan was thru rusted at 121k... it was a plow truck before I bought it.
Old Jun 15, 2020 | 08:34 AM
bigb56's Avatar
bigb56
If you could get the VIN from the donor truck you could run a Carfax.
Old Jun 15, 2020 | 08:54 AM
tatesomero's Avatar
tatesomero
Yeah you don't need a lot of mileage for a lot of rust. Mines an 02 with 153k in NH and manifolds are about shot, bolts to up pipes are gone and oil pan just started seeping. And I undercoat my truck too. Doesn't take a lot of salt driving and sitting in humid freeze/ thaw can rot it out. Local guy was telling me the block will rot right out around these parts.
Old Jun 15, 2020 | 09:26 AM
z31freakify's Avatar
z31freakify
I wouldn't worry about outside rust, i would be more concern with the internals.
Old Jun 16, 2020 | 12:56 AM
Red Sonja's Avatar
Red Sonja
is there anyway to get the VIN from the engine SN or whatever number is stamped on it? that should be like matching an engine to a chassis for authentication purposes of a classic car/truck.
Old Jun 16, 2020 | 06:33 AM
JayTheCPA's Avatar
JayTheCPA
Well, it is yours now. Apologies as that may have come-across as rough, but it is what it is.
What is the goal of a VIN? Sue the seller if things do not add-up? Hope not as that will cost more than buying a couple remans.
As others noted, photos are showing rust that is common. I have less mileage than that on my motor and even the valve cover bolts are gnasty. Manifolds started to look like artichokes with all the layers of rust 15 or so years ago.
These trucks have not taken well to brine as they were built before that carcinogenic stuff was put on roads.
Point is, either fixate on the rust and get frustrated, or start planning a way forward. At this point, something is telling me that the more economical path would have been to go with a reman which came with at least a minimal warranty.
Old Jun 16, 2020 | 09:41 AM
Walleye Hunter's Avatar
Walleye Hunter
I agree with the others on that rust from the great white north and on the HPOP...they rarely go bad but frequently get accused of being the problem and get replaced unnecessarily. One thing I don't understand is that they say that rebuilt HPOP's generally don't last long but the performance HPOP's are mostly rebuilt ones.
Old Jun 16, 2020 | 12:28 PM
z31freakify
it's the ones with those tags that dont last. Ask Byron BBslider.
Old Jun 17, 2020 | 01:56 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I'd go ahead and replace rusty bits like the oil pan now while it is out and you can do it properly. Exhaust manifolds and/or bolts too.
The 142k is the easiest number for them to grab so I'd expect it to be correct.
Is your 99 early or late? Now is the time to update to late. Plus the usual goodies like bellowed uppies and at least a billet wheel for the turbo, unless you can do a better turbo in your area.
To me it all looks good so far.
Old Jun 17, 2020 | 07:26 AM
Dan V's Avatar
Dan V
I damn sure wouldn't put that engine in without replacing the oil pan.
Old Jun 19, 2020 | 03:21 PM
Red Sonja's Avatar
Red Sonja
OK, not sure yet what i'm going to do about that reman HPOP but i am doing the following:
  • Oil pan from my '99 7.3 which looks great and already has a well sealed oil dipstick using the Moroso gasket with studs (from Riffraff)
  • GTP38R, bellowed up-pipes and Rosewood 160/80's (i'm rebuilding) from my '99
  • using my '99 exhaust manifolds with all new (Motorcraft) bolts
  • Cerakote C-7600 the whole hot side (manifolds, uppies, "Y" and turbine housing
  • EBPV delete including pedestal and high flow outlet from Riffraff
  • CCV delete custom built
  • AIH delete (WOW, maybe just "delete" the whole 7.3, lol)
  • Input plenum inserts and all new charge system boots
Think that I will start a "build" thread with photos
Old Jun 22, 2020 | 09:28 PM
Macmathews's Avatar
Macmathews
Internals of what ?
Kyle
Old Jun 23, 2020 | 09:27 AM
BBslider001's Avatar
BBslider001
Yeah, replace that HPOP with either a factory used one from a parts truck or drop the coin for a new one. That would be my first order of business.
