Really, 142K ??
Old Jun 23, 2020 | 10:53 AM
Red Sonja's Avatar
Red Sonja
About the engine "internals", I sent an oil sample off to Blackstone Labs a week ago and expect numbers soon. If those numbers are fine (unfortunately, I didn't have a mileage for the oil change interval), I'm just going to assume that the internals are fine with only 140K. I already had a "Master Service" kit for the HPOP from TamerX that I purchased months ago (forgot about it). I will use that if/when the reman fails as they aren't that difficult to access after engine is installed.
Old Jun 23, 2020 | 11:21 AM
BBslider001's Avatar
BBslider001
Word of advice....DO NOT wait until it fails. Not only will it leave you stranded, but it will send metal particles through your oiling system. Do what you want, but I said "first order of business" for a reason.
Old Jun 23, 2020 | 12:13 PM
Walleye Hunter's Avatar
Walleye Hunter
And how do you know? (I just had to ask).
Old Jun 23, 2020 | 01:19 PM
BBslider001
LOL Mark...Adam and I both know unfortunately. That was a good truck too. BUT, I got into a Superduty and won't look back, so for that, I am thankful.
Old Jun 23, 2020 | 02:54 PM
Red Sonja's Avatar
Red Sonja
What mode of failure would cause metal fragments? From what I have read, the usual problem is leaks and low pressure... what do i replace that could cause the more catastrophic failure?
Old Jun 23, 2020 | 06:23 PM
BBslider001
The whole pump.
Old Jun 24, 2020 | 08:48 AM
JayTheCPA's Avatar
JayTheCPA
. . . I sent an oil sample off to Blackstone Labs a week ago and expect numbers soon. If those numbers are fine . . .
Might consider not putting much / any faith in that oil analysis result. Reason is that the sample will have skewed results as it come from a stratified layer based on where the sample was taken. If the sample was from the drain plug, it will have all the heavier metals that settled and indicate that the motor might need more work than it really does. If the sample was pulled from the dipstick, it will have results based on where (higher / lower) in the pool the tube reached and might incorrectly indicate that things are great.
Ideally, the sample should have occurred after the motor reached operating temperature and shortly after motor shut-down. This would have all the items still floating around in a mix. With a motor siting for a long time, all the floaters will settle based on their specific gravity.
Old Jun 24, 2020 | 07:36 PM
T-wood's Avatar
T-wood
Red
So I'm really curious what does a motor with 142k cost?
Ive put a hpop in a motor that had 117ish miles. Sometimes I think it's the years that takes its toll. These motors leak enough fuel or oil at some point or another. I think sometimes that protects the motor.
B
52Flthed
Mar 18, 2020 06:17 PM
nasty49
Nov 16, 2017 06:08 PM
sniper250
Texas Chapter
Aug 25, 2010 09:16 AM
Kep4
S. California Chapter
38
Mar 17, 2009 06:21 PM
Kep4
94
Jan 1, 2009 05:27 PM
