2WD Leaning
Old Jun 11, 2020 | 12:33 PM
symonds86's Avatar
symonds86
capt google says a group 65 weights 41.5 pounds
Old Jun 11, 2020 | 03:24 PM
kenny nunez's Avatar
kenny nunez
Battery weight
The Northstar I have in my 68 weighs 75 lbs and it does give my truck a lean on the right and I plan on addressing that soon with adjustable coil overs.
Old Jun 16, 2020 | 11:18 AM
diggerrigger's Avatar
diggerrigger
Originally Posted by oft
if I were to add a coils spacer to one side only, it wont jack up the ride? As in I hit bumps and the 2 springs react differently?
I just learned something about this while working on my front suspension yesterday. The front coil springs sit on top of a spacer. These spacers are different heights. In most cases, the taller spacer goes on the right, passenger side. This is intentional in order to level the truck. If your truck's spacers were removed before and then accidentally replaced on the wrong sides, it would make the truck lean by a factor of two times the difference is spacer height.
My truck's spacers are only a quarter inch in difference. However, while researching this I found applications where the difference was up to three quarters of an inch. It's very easy to measure them.
Maybe this will help.
-Digger
Old Jun 16, 2020 | 01:03 PM
'77F250C's Avatar
'77F250C
-Digger
I’m going through this too so awesome information to know. What spacers did you use ?
Old Jun 16, 2020 | 02:14 PM
diggerrigger
Let me just give you what I started yesterday. Coil Spring Help
Old Jun 2, 2021 | 11:08 AM
bluesixthgen2018's Avatar
bluesixthgen2018
Trailering
Hello oft.
I managed to find a bit of a solution by accident while working on my 79 f150. When I purchased my truck, it came with a set of worn out, (and incorrect) radius arm bushings. I later swapped them out last summer. And even though it did not fully eliminate the leaning toward the passenger side, there was however, a dramatic improvement. Wasn't sure if that was something you had checked on your truck. Hope this helps.
75F350
Offroad & 4x4
70
Dec 17, 2015 09:46 AM
SatinBlack03
May 15, 2015 05:01 AM
graduate
Mar 25, 2015 01:47 PM
pat420swed
1978 - 1996 Big Bronco
Apr 15, 2014 04:46 AM
KIKKUP
Oct 23, 2012 09:07 PM
