ac compressor
Old Oct 18, 2003 | 02:47 AM
nybeat's Avatar
nybeat
ac compressor
just recently i've been having this problem with my truck. when ever the a/c compressor clicks on the engine stumbles really bad for a second and then comes back up to where it is supposed to be. i know the rpms are supposed to drop a little bit, just because of the fact that there is a load being put on the motor, but it drops to where it is about to die, and then comes right back up. has any one ever had this problem or have any idea what it might be? thanks in advance!!! :-)
Old Oct 18, 2003 | 01:53 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
You didn't tell us about you truck but I would start by cleaning the IAC.
Old Oct 18, 2003 | 03:53 PM
nybeat's Avatar
nybeat
sorry, my truck is a 97 ranger with a 2.3. 140,000 miles. what does IAC stand for? thanks!!!
Old Oct 18, 2003 | 04:35 PM
ctfuzzy's Avatar
ctfuzzy
Great Scott!
Originally posted by Ken00
Welcome to FTE!!!
"clening"
Isn't that a Scottish thing? Can you do that in America (without being arrested) ??
<== see why I like this little guy so much? - He fits.
Old Oct 18, 2003 | 07:34 PM
Ken00's Avatar
Ken00
I'm not sure what you mean ctfuzzy, LOL. It's good to be the moderator, you can fix your spelling mistakes.
IAC = idle air control valve, normally located on the throttle body.
Old Oct 18, 2003 | 08:20 PM
ctfuzzy's Avatar
ctfuzzy
I'm not sure what you mean ctfuzzy, LOL. . . .
i was just teasing, Ken. It does sound Scottish though.
Old Oct 19, 2003 | 06:36 PM
Ken00's Avatar
Ken00
I know, I went back and corrected my mispellings.
Old Oct 24, 2003 | 02:17 PM
nybeat's Avatar
nybeat
thanks,
i'll clean the iac, and get back to you guys if it doesn't work!!! :-)
Old Oct 24, 2003 | 08:48 PM
wolfen's Avatar
wolfen
Welcome to FTE nybeat,
Got to watch out! The FTE family does break loose now and then and you're now here too!
HUUUAAAAAAAA!!!!!!!
______________________________________________
‘90 Ranger: 2.3L, EEC-IV, EFI, DIS, 2wd, Mazda 5sp
Old Oct 27, 2003 | 09:51 PM
RA72925's Avatar
RA72925
Banned
Could the IAC cause any other problems with the AC system? I know I wrote about this not too long ago, but my compressor seems to be acting strange on my '94 4L V6. It will click on and I can feel cool air through the vents. It cycles a few times, and randomly it will kick on and blow warm/hot air (depends on how hot it is outside).
I've recharged the system. I guess it could be a leak somewhere. Any clues?
Oriteon
Old Nov 5, 2003 | 01:26 PM
rdg's Avatar
rdg
I have the same problem. idle lope bad when the a/c compressor turns on. - no check engine light though. Have you found a solution? Please let me know- I have the 98 4 cyl 4X2
Old Nov 5, 2003 | 03:05 PM
rdg's Avatar
rdg
Old Nov 5, 2003 | 03:12 PM
ctfuzzy's Avatar
ctfuzzy
rdg, it could be as simple as needing a tune up.
How many of those 140,000 miles since it had plugs & filters?
Old Nov 5, 2003 | 03:15 PM
rdg's Avatar
rdg
mine has 75,000 on it now, i already replaced the plugs and wires with new ford parts. i can consistently drop the idle below 500 rpm when the a/c is turned on. the a/c clutch also seems to cycle more than it should. i check the iac and it passes the resistance check and the unplug check. not sure what next?
