check engine light
Old Nov 5, 2003 | 07:46 AM
jdotoli's Avatar
jdotoli
Smile check engine light
Check engine light.
1995 Ford Ranger; 3.0L, 5-speed, 2 wheel drive, custom exhaust, superchip, K&N air intake. Truck runs good. New tune-up, EGR valve, IAC valve. My mechanic friend read Evap code. Replaced some vacumn lines. Reset light but comes back on after 15 miles. Reset light several more times but comes back on each time after driving first 15 miles. Sometimes light will go off by itself for an hour or even for a day or two but always comes back on. Any ideas???
Old Nov 5, 2003 | 09:36 AM
Rockledge's Avatar
Rockledge
Evaporative Emission Control System Thread
Hi welcome to FTE!
What number code(s) are you getting? If you can be more sepcific about the trouble codes then you'll probably get better feedback.
FWIW, here is a thread from the 3.0L V6 Forum that may or may not be relevant:
Hope this helps. Good luck.
Old Nov 5, 2003 | 04:50 PM
jdotoli's Avatar
jdotoli
Thanks, I'm not certain which codes but let me see what I can do about getting that info.
