I’ve replaced everything on the front suspension on my 97 SC F250. All new steering gear (blue top), shocks, front springs, bushings, tie rods, etc. I even swapped the old intermediate shaft with a Borgeson solid type. I have a bit of play in the steering still. I can rock the steering wheel about 1/2” left to right without any real effect on steering. I don’t get any wander and truck tracks perfectly straight. Would a front stabilizer shock tighten/improve the “feel” of the front end?
If you have play in the wheel that isn't moving the tie rods at all, a steering stabilizer will have no effect on that.
A lot of times, that play is from the tie rods moving a little bit, the gear in the steering gear boxes meshing, the joints in the column coming together, etc adding up. Even brand new parts will have a little bit of "slop" to them, or the whole system would be all bound up.
New leafs, pivot bushings. It’s possible that I’m expecting tighter steering than the truck came with new. I don’t have any wander, I would just like a tighter feel from the wheel to the road.
Steering box- if that 1/2" of turn isn't doing anything to the output shaft of the box, NOTHING'S going to change.
Toe- too much toe- in will give you nice, stable steering at the expense of some road feel.
Easy to test by adding just a 1/6th turn out on each side and see if the feel changes.
Maybe I haven't spent as much time in the '93 as I should in order to answer this with actual knowledge, but at just 1/2" play in each direction, that sounds extremely tight for an old truck with a gearbox instead of rack-n-pinion steering.
I thought that was just the nature of the beast. If you get zero play that would really be something I think.
So yes, that sounds normal for a truck of even '97 vintage. That was the last of the old body style, and as far as I know they used the same steering gearbox all the way back to '80. Maybe with some modifications, but probably not much.
However, there are things that do create looseness in the old trucks that can be gotten rid of. Cracked frames and crossmembers (especially on the TTB trucks) worn out or flexy tie-rods (especially notable with larger tires), loose wheel bearings, worn out tires, etc, etc, etc.
Is your truck stock, or lifted? Are the tires stock size, or larger?
None of the above necessarily adds "play" to the system, but they can exaggerate the symptoms.
Good luck.
But I'm still thinking it's normal.
Paul
I agree 100%.
The tires start turning after only 1/4” of movement from the steering wheel. You won’t get the same kind of road feel from a recirculating ball gearbox that you do from rack and pinion. is this your first vehicle without rack and pinion? Just curious.
Crack the lock nut holding the adjustment screw on top of steering box loose.
Turn the adjustment screw in/clockwise 1/4 turn & hold while tightening down lock nut.
If this eliminates your play, enjoy. You now have two options.
A) go to junk yard & get an identical box & send to Red Head for rebuilding. B) wait till it wears & get looser than before & then send your original to Redhead & wait.
Originally Posted by mrollings53
Don't these trucks still have rag joints?
Yes but not on his truck. He has a Borgeson shaft with u-joints.
It has a brand new steering gear. I don’t think there is anything wrong with 1/4” of play off center. It is probably just as good if not better than when it was a new vehicle.
I’m thinking it’s just normal for the truck. I didn’t realize that steering gear vs rack and pinion was a contributing factor. Since everything is basically new, I think I should just be happy it’s as good as it is. I have a small lift (leveling kit) and nearly 35” tires, so aim sure this plays a role as well.
Yes. Sometimes it plays a HUGE role!
You might have play simply while waiting for the tire's sidewalls to catch up with the wheels.
You might have play while waiting for the steering linkages, now possibly at steeper angles try to catch up.
Suspension lifts and big tires are a part of life, but it's a fact of that life that they change the way a vehicle acts and reacts when compared to stock.
Overall though, it sounds like yours is doing fantastic for what it is.
