Need some help with brakes
Old Jun 9, 2020 | 11:53 AM
jstihl's Avatar
jstihl
Originally Posted by Brian Hanks
hope yours was better than mine. Had EXACTLY the same symptoms recently. Had to do both calipers and lines.
noticed the pistons were a little “sticky” when changing pads and rotors about 8k ago (difficult to compress) and thought it was just a super duty thing. Considering the age I should have known better... lines also were deteriorating to point of causing the inner lining to make the dreaded valve effect.. not sure if this is correct but I was always told to replace both sides when doing calipers and lines. Honestly they both needed it and the other was about to go and be right back to the same spot.
which calipers did you end up going with? There are so many mixed reviews from other threads I'm not sure which one to go with. The only one that seemed to have consistent good reviews were the ssbc? I think that was it, but of course they are like $1,100 . Is it true that you should go with steel pistons for our trucks? Mixed reveiws on that also lol
Old Jun 9, 2020 | 12:06 PM
SkySkiJason's Avatar
SkySkiJason
I use lifetime warranty calipers from local autoparts.
If they are sticky/hard to compress or any deterioration of boots/seals, I change them at pad change.
Also using 3yr warranty rotors and will swap them if any sign of warping or heat stress at pad changes.
None of these parts last forever. You can spend more on ‘fancy’ stuff that doesn’t perform any better and has no warranty - or less from some online retailer that makes it difficult to use ‘warranty’.
Ive had my dually since 2003. I paid for calipers all the way around (1) time.
Old Jun 9, 2020 | 12:20 PM
jstihl's Avatar
jstihl
I can get motorcraft rotors at a deep discount with a 2-3 year warranty or napa for the same price with a lifetime warranty. Decisions Decisions
Old Jun 9, 2020 | 12:36 PM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by jstihl
what did you end up swapping? The caliper?
Ol' Dan there swapped out his entire axle and many other bits and pieces.
https://www.ford-trucks.com/forums/1...read-done.html
Yup, the SSBCs are great. That said, I would not pay full price for them and got a NIB set off eBay for about 60% of retail price. They're the only "big brake" kit that fits inside factory wheels too.
Old Jun 9, 2020 | 01:38 PM
pvdiag's Avatar
pvdiag
Further to FTNoobs suggestion on the pistons seizing: my rear brakes have been a pain in the rear. I recently replaced everything back there, including a total flush of fluid. I did a post mortem on the calipers and noticed a small ring of rust in the bore where the piston lives. Since there is no force to pull the pistons back upon release of the pedal, the only thing pushing them back is the rolled up square oring and whatever dynamic establishes itself with the rotating disk. In other words - jack squat. Likely not enough to overcome whatever resistance a ring of rust presents. The end result is that the piston never fully pulls back.
And that ring of rust? I believe that is from water being absorbed in the brake fluid - BF loves it some moisture. The spec for these old dogs is DOT3 fluid. DOT4 has better hydroscopic properties than 3 and doesn't take up as much water. It is an acceptable replacement.
Keeping the same calipers and switching to DOT4 will not reverse the problem, but I am of the belief it will minimize it moving forward - once new components are installed. I guess this would also be a plug for changing out the BF early and often, as I intend to do. I am on my 2nd set of rears in 6 yrs and 25k miles. This includes new hoses also.
Old Jun 9, 2020 | 04:05 PM
jstihl's Avatar
jstihl
couldn't find any ssbc on ebay so I guess I'll have to go with the cheapies. Does anyone know if I got the motorcraft calipers , if they have the upgraded slide pins ??
Old Jun 9, 2020 | 05:11 PM
SkySkiJason
Just buy ‘bracketed’ calipers and get new slide pins, boots, etc.
Replace the lube they come with with dielectric grease.
Old Jun 9, 2020 | 06:33 PM
Wes444's Avatar
Wes444
Originally Posted by pvdiag
..upon release of the pedal, the only thing pushing them back is the rolled up square oring and whatever dynamic establishes itself with the rotating disk. In other words - jack squat.
Actually that is inaccurate. There is a "spirng" to decompress the calipers. It's a joke of a design. It's that paperclip sized wishbone shaped spring that goes from pad to pad. Replace those with the new ones (or reuse previous if they feel stronger than new one that come with pads) during every pad change
Old Jun 9, 2020 | 08:21 PM
pvdiag's Avatar
pvdiag
The square cut oring is by design meant to act as a spring. Below is a link to a quick read write-up on them in a disc brake app. Sure that wish-bony spring is supposed to help retract the pads, but I haven't experienced them to be effective at all. They certainly don't have the umpha to overcome the resistance caused by minor rusting.
O-Rings
Old Jun 20, 2020 | 01:00 PM
jstihl's Avatar
jstihl
You can remove wheel and attempt to compress caliper with a smal prybar. The pistons should be able to be pushed all the way into bores pretty easily. ‘Stuck’ pistons require caliper replacement.
You can try opening bleeder screw if pistons appear stuck to rule out a bad hose.
I also forgot to mention you should always change all of the brake fluid each time the brakes are serviced.
I do this by slurping all of the fluid from reservoir and filling with fresh fluid (from an unopened/new bottle of fluid), then open all caliper bleeders and let it ‘gravity bleed’ until the new fluid comes out. Don’t let reservoir run dry!!
Brake fluid is hygroscopic and will absorb moisture over time. Contaminated brake fluid is corrosive to carbon steel and shortens caliper and other component’s lifespan.
im going to be bleeding my brakes soon and would like to use this gravity method on all 4 wheels, was just wondering if i need to pump the brakes while doing it this way or not? Also would i need a helper to fill the resevoir or does the fluid drain out slowly enough to do it by myself?
Old Jun 20, 2020 | 01:32 PM
Ridedan2's Avatar
Ridedan2
The majority of my brake problems have been with the pins stuck from rust. With that said I have since found this stuff and have not had a problem again.
Amazon Amazon
as for gravity bleeding, it is difficult to gravity bleed the rears, especially rear passenger side. You will likely find you need to bleed them as usual with 2 people. Just my 2 cents man.
Old Jun 20, 2020 | 01:42 PM
jstihl's Avatar
jstihl
https://www.amazon.com/ACDelco-10-40.../dp/B0026JK8FU
Thanks ridedan, do you know approximetly how many quarts of dot3 i will need to do a complete flush?
Old Jun 20, 2020 | 01:50 PM
  #28
Ridedan2's Avatar
Ridedan2
Out of memory, I’m pretty sure I used 2 quarts when I replaced all my brake lines and bleed them. It may be worth just getting 3 quarts, and if the third is not needed, you will have it on the shelf for another day. I think there about 8 bucks a quart at NAPA an probably a few bucks less at Walmart- I’ve had no problems with Walmart fluids.
Old Jun 21, 2020 | 06:17 AM
  #29
SkySkiJason
Gravity bleed is slow, no helper needed. All 4 corners will bleed this way. Do NOT pump the pedal. You’ll need a helper for conventional 2-man bleeding method.
1 quart is probably adequate to replace all of the fluid if you start by slurping all of the fluid from reservoir.
Old Jun 21, 2020 | 04:02 PM
  #30
crop harvester's Avatar
crop harvester
I was always lead to believe the little bit of run out in the rotors is what keeps the pads/pistons pushed away from the rotors.
