Need some help with brakes
Gravity bleed is slow, no helper needed. All 4 corners will bleed this way. Do NOT pump the pedal. You’ll need a helper for conventional 2-man bleeding method.
1 quart is probably adequate to replace all of the fluid if you start by slurping all of the fluid from reservoir.
The pistons being out does not affect air bleeding. But will require additional fluid to top off reservoir when you do pump the brakes after closing bleeders.
When you do pump pedal to push the pistons out, use short strokes. We want to avoid pushing master cylinder piston past it’s normal point of travel. When using 2-man bleed method, use a block of wood under pedal to limit travel.
If you ‘pump the brakes’ with bleeders open, you’ll suck air in...
the front brakes have new fluid coming through but the back has pretty much stopped flowing even with the front bleeders closed. Is this normal?
Sometimes, you can close bleeders and pump the pedal slowly until it gets hard and then try to gravity again.
Sometimes, ya gotta use pressure/vacuum or 2-Man...
I've tried using pneumatic suction bottle and no matter how much fluid I suck out my pedal is still spongy. Do I just keep pulling fluid from each corner? Not really sure what the heck went wrong
A little story:
I serviced my rear brake calibers in last winter.
I scratched my head for a while,why theres no air coming from the bleeder!
Previous owner/servicer had flipped the calipers from side to side!
Bleeders were pointing down!
Swapped calipers and loved the sound of air coming from those bleeders!
A little story:
2-Man method is what I would do if struggling.
thats a bummer, already went through 3 quarts. It doesn't matter that I'm leaving the cap off does it. I'm not letting it run dry
