Build thread...done
Old May 31, 2020 | 07:38 PM
Dan V's Avatar
Dan V
Build thread...done
This project has been a long time in the making. It all started some 5-6 years ago when I was looking for some rust free doors for my 2001.
I did find some Texas doors….attached to a cab. The cab is titled. The cab and doors received sound deadening materials as well.
I noticed a that he also had a blasted and epoxy coated frame…which I brought home too.
It was a leaf spring frame, and it received a coil spring front axle from a 2007. Rebuilt the front axle using Spicer ball joints and steering parts….and oh, 4:10 gears to match the 2008 4:10LS rear axle. Denny’s Driveline for those parts. That rusty steering gear is from a 2015 F350.
The 2015 steering gear (it’s really nice, turns with minimal effort) presented a couple of challenges. 1) the bolts holding it to the frame are huge, and drilling the frame out is terrible. And 2) The bigger gear gets in the way of the front sway bar mount.
A picture of the D60 front ring gear pattern after swapping the 3.73 for 4.10.
Drive side
So then I found a 2008 4:10 LS rear…mounted that up. (had to remount one of the shocks on the frame). Installed a B&W turnover hitch and some air bags. New rear springs from ATS.
Also installed independent ride height sensors left and right.
Oh, you saw the air hose?
Viair 400c feeding a 3 gallon SSTL tank. And if you have OBA, you might as well have some access to air.
I had run the S&B intake, but I was never really happy with the Gen 1 fit and the cheesy battery tray, so some coin to RiffRaff and some left over 4” exhaust tube. It went together well, and with the SXE364.5, there is no increase in noise.
The bumper is a Move DIY. That was a fair amount of work, and the powdercoat company brought in a textured color that is a pretty good match for the Raptor grill.
The sandblasting brought out a few pin holes in the welds that I didn't get to address before the pain was applied...oh well.
Some LED lights from Super Bright LED rounds it out. When I had the dash out I did wire for the turn signals and heat for the mirrors.
I still have the interior to finish, the wait time from the Leather Seats covers is 5 weeks….and some NFab SSTL steps. I might (probably) go with pocket fender flares.
Old May 31, 2020 | 07:46 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Dan, I am envious of your skill and determination. Well done sir!
Old May 31, 2020 | 08:27 PM
z31freakify's Avatar
z31freakify
Sweet build Dan, truck looks great and that frame is something to slobber at.
Old Jun 1, 2020 | 05:51 AM
FordTruckNoob's Avatar
FordTruckNoob
Congratulations Dan! That bumper (among many other things) turned out great. How's she drive?
Old Jun 1, 2020 | 07:05 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Classic case of snowball!
looks great, awesome work !
Old Jun 1, 2020 | 07:08 AM
Dan V's Avatar
Dan V
I won't complain about tire noise to you....but with all the sound deadening products in there....that's the bulk of the noise now. She drives straight and true, I would have liked the alignment shop give a bit more caster (it's 2.5 both, would have liked to see it up around 4).
Now it's just checking/re-torquing things like the gooseneck hitch, spring u-bolts, any suspension brackets that were installed with the coil spring front.
Old Jun 1, 2020 | 07:32 AM
KubotaOrange76
That gear pattern looks damn near perfect, I cant ever seem to get them centered and deep like that, was coast side centered too?
Old Jun 1, 2020 | 07:34 AM
FordTruckNoob
LOL indeed
Is the ride a lot smoother with that coil front? Have you gotten her up to speed to check for death wobble?
Old Jun 1, 2020 | 07:38 AM
Dan V's Avatar
Dan V
Coast side.
Old Jun 1, 2020 | 07:42 AM
Dan V's Avatar
Dan V
LOL indeed
Here's the thing...I'm sure the front is better over the bumps, but the rear got firmer with the 3300lb springs. (it had 3000). I carry a bunch of pin weight with the horse trailer, but in hindsight (and I might just do it) is talk with Junior @ATS about pulling a leave. That would lower the spring rate, and I still have the air bags for ride height. You'll note the overload...that will never touch unless I have an air bag failure....which has happened....and the only reason I spec'd the springs with the overload.
Death wobble....just had to go there didn't you?
Old Jun 1, 2020 | 07:47 AM
Dan V's Avatar
Dan V
I need to give a shout to @Nicmike . He is the author of a glorious coil spring conversion thread that I used a lot to do the swap, and figure out the power steering hoses..the 2015 box is a new twist on it.
Old Jun 1, 2020 | 07:55 AM
FordTruckNoob
Here's the thing...I'm sure the front is better over the bumps, but the rear got firmer with the 3300lb springs. (it had 3000). I carry a bunch of pin weight with the youhorse trailer, but in hindsight (and I might just do it) is talk with Junior @ATS about pulling a leave. That would lower the spring rate, and I still have the air bags for ride height. You'll note the overload...that will never touch unless I have an air bag failure....which has happened....and the only reason I spec'd the springs with the overload.
Or just carry sandbags when unloaded/not towing? Alternatively, lower rear tire pressure and air up when you have to since you have OBA.
Sorry. Touchy subject?
Old Jun 1, 2020 | 08:01 AM
Dan V's Avatar
Dan V
Touchy? Not to me, but go over the 2017+ forum, search that term....and you can read for about a week. If I experience DW, I know how to fix it. I've got about 1000 miles on it, probably 300 pulling the trailer. The turning radius is nice, but you probably wouldn't see that gain with those thing you call tires on your truck. And the the bigger brakes....are nice.
Old Jun 1, 2020 | 08:04 AM
Dan V's Avatar
Dan V
I'm going to have it in town tomorrow, picking up the NFab steps. I'll throw your bender in and we can meet up.....somewhere where the city isn't on fire.
Old Jun 1, 2020 | 08:08 AM
FordTruckNoob
What? I know not of these 2017+ trucks you speak of. I am firmly planted in the Mesozoic Era of trucks.
Nice. I was going to ask about the improved turning radius but then you took the wind out of my sails. Good to hear about the bigger brakes too.
