Help with Decision
Old Jun 16, 2020 | 08:19 AM
  #31
nuctrooper's Avatar
nuctrooper
Originally Posted by allendks45
Thanks Jim!
We were concerned and called Lance directly. They assured us that as configured our truck was well within specs with full load but not counting what we added to beyond that. They pointed me to a build they did with similar truck configuration here https://www.lancecamper.com/altimeter/ Right now we are at 6,753 for curb weight. Don't have rear sway bar and was going to see how it handled first with the air-bags before adding one. The original plan for the truck was an 'Overland Build' which is the reason for a $10k suspension which handles off-road unbelievable. So it looks like we will be close to max but not quite. I'm happy we have E-rated tires at 3750 each which will keep us within GAWR.
No rear sway bar? That won’t be just an easy test, that will be a scary drive and you will actually wonder if you are about to roll over. After the third heart attack you’ll promise yourself to install a sway bar before your next trip. Be sure to take some antacid with you - you’ll need it.
Old Jun 16, 2020 | 10:09 AM
  #32
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
I totally agree, BUT for "Offroad" reasons, I also see his point - a swaybar severely limits axle travel when in rough terrain. The ideal thing would be to have some kind of "Quick Disconnect" for the arms that go from the ends of the sway bar, up to the frame AND some sort of hangar to keep the swaybar from dropping once disconnected!
crewzer
All Things Towing
56
May 15, 2019 05:22 PM
Foamster
2015 - 2020 F150
24
Jul 23, 2018 08:16 AM
poodlemaster187
May 10, 2017 05:46 PM
SlickYamaha
Apr 13, 2012 04:52 PM
glennemay
Apr 13, 2010 11:55 PM
