Which clutch?
Old Jun 7, 2020 | 03:15 PM
Branden Heine's Avatar
Branden Heine
Which clutch?
I’m wondering which clutch I should use for my truck I just picked up the new 300 straight six for my truck and the motor is from 1980 with a aluminum bell housing my truck has the 1966 factory 4spd in it and I measured the bell housing and my transmission and it will bolt to it and the shaft coming from the front of the transmission is long enough to work with the bell housing and motor the 1980 motor and my truck both had mechanical clutches so I guess my question is which clutch should I use the one from 1980 or the 1966 style clutch but I guess it may depend on fly wheel possibly not to sure?
Old Jun 7, 2020 | 03:21 PM
ford390gashog's Avatar
ford390gashog
The 1980 should have a diaphragm pressure plate and the 66 will have the 3 finger. You get better pedal feel with the diaphragm but also slightly lower holding power.
Old Jun 7, 2020 | 03:26 PM
Branden Heine
you are right the 80 is diaphragm which would be better for my truck as my truck won’t be pulling a trailer or hauling anything heavy it’s just gonna be a cruiser I was thinking about using the 66 style because I have a new one in box that I bought for my 67 f250 but rock auto says the 66 and 67 clutches are the same I’ll just have to order another for my 67 if I use the the 3 finger one
Old Jun 7, 2020 | 09:13 PM
rdixiemiller's Avatar
rdixiemiller
I ordered a 1983 351W clutch when i was installing the NP435 transmission. Its a diaphragm type pressure plate. However, it won't bolt up to my 1978 302 flywheel. Since the original pressure plate was fine, I re-used it and just installed the new disc, throwout bearing, and pilot bushing.
You may want to check before you order.......
Old Jun 7, 2020 | 09:18 PM
Branden Heine
I’ll just have to check if my 3 finger clutch will fit since I already have a new one
Old Jun 8, 2020 | 09:39 AM
rdixiemiller
Yep.
I have a diaphragm pressure plate (11') sitting in the shop. I'll snap a pic tonight.
Old Jun 8, 2020 | 11:11 AM
Branden Heine
Yep.
I just need to know which one fits and will be best for my application
Old Jun 8, 2020 | 03:13 PM
rdixiemiller
Which one fits, depends on your flywheel.
At least on this particular 302, the flywheel is drilled for the Borg and Beck (3 finger) flywheel, and not the diaphragm style.
Then again, it could just be this particular pressure plate.
Old Jun 8, 2020 | 11:46 PM
HydroDog's Avatar
HydroDog
I’m going through this right now and I’m changing from the three finder to the diagram style on my 300 six in my 1965 f100.
I got a new flywheel from NAPA with ring gear for $75 and the diaphragm clutch kit was $150.
Im working on rebuilding the Z-bar and the rest of the clutch linkage.
The reason I went with the diaphragm was from past experience back in 1985 when I put the last clutch in. I had to go through a stack of remanufactured pressure plates to get one that the fingers were all the same height after bolting the pressure plate to the flywheel.
Old Jun 9, 2020 | 07:32 AM
62SY4's Avatar
62SY4
Correct it appears the aftermarket supports both finger type (long/b&b) or diaphragm type for both the 1966 and 1980 applications. Which to use is a preference.
It sounds like the OP has a clutch for an earlier application, why not unbox that cover and try to hang it on the 1980 flywheel and let the world know if the mate?
Edit:
Quickly looking in some books, looks like late 60's trucks with 300-6 used an 11" clutch that is the Long type. The 80's 300-6 trucks could have either a 10" Long pattern or 11" with the Borg and Beck pattern. Again any of these are available today in a finger or diaphragm type replacement.
But again, in 40-55 years any mix and match could have occurred, so per my comment above, the only way to know if the clutch you have will work, is to try.
Old Jun 9, 2020 | 06:54 PM
Branden Heine
Update
I tested the 66 style 3 finger clutch on the 1980 motor that has the diaphragm style the 66 clutch is a 11 inch clutch and the 1980 motor has a factory 10 inch clutch so it will not work and the bolt hole are off by half a inch so I guess I will go with the diaphragm style for my truck and I did the measuring on my 66 4spd transmission and it will work is there anything special or little I will need to change like linkage or something
Old Jun 9, 2020 | 08:14 PM
Rusty Fords's Avatar
Rusty Fords
Is your transmission a NP435 and does that one have a transmission support on it?
Old Jun 9, 2020 | 08:22 PM
Branden Heine
yes it is I think that was the factory f100 transmission in 66 and yes it has a mount that connects to the crossmember at the back of the transmission
Ctjkre
Jun 6, 2019 06:33 AM
76WYOF250
Jul 10, 2014 02:12 AM
Jeff Van Housen
Nov 2, 2005 01:32 AM
teekey
May 14, 2003 12:43 AM
gdaf
Oct 14, 2001 04:53 PM
