390 cam suggestions ...
Old Oct 17, 2003 | 10:31 PM
gktbay's Avatar
gktbay
Question 390 cam suggestions ...
Closing in on the main item --- the bump stick.
'66 Shortbed F100 2wd
390 / .030 bore Speed Pro piston L-2291F flat/4 valve reliefs
C8AE-H Heads / 69cc chamber --- probably non-adjust. 'shafts
modest gasket matching - cyl. heads and intake runners
Edelbrock Streetmaster manifold - may use 1" spacer again
Vintage Carter AFB 625cfm (never a "Holley moment")
C-6 / stock converter
may go 3.70:1 at rear axle ; rear rubber not taller than 28"
My best friend said,"get a Woodin Cam ... sounds great, goes woodin-woodin when you rev it". Yep, I hit him ... hah!
Seriously, any ideas gents --- prefer hydraulic and looking for noticeable non-stock sound at tailpipes.
Thanks
Old Oct 17, 2003 | 10:37 PM
Ratsmoker's Avatar
Ratsmoker
Crane 343941. Any bigger will require a rocker shaft upgrade.
Old Oct 17, 2003 | 10:54 PM
gktbay's Avatar
gktbay
Thanks.
Will stock valve springs work.
If you have used this grind before, how does it sound and where did you find its power range noticeable?
Old Oct 17, 2003 | 11:00 PM
Ratsmoker's Avatar
Ratsmoker
A few people here have used it and all seem to be very happy. You have to get the recommended springs, locks and retainers. I use the 343801 cam. It lopes pretty good. The 941 cam should pull well up to 5,000.
Old Oct 17, 2003 | 11:07 PM
gktbay's Avatar
gktbay
Can do.
The 801 ... does it work well with an auto trans? Looking for noticeable cam sound also.
Old Oct 17, 2003 | 11:20 PM
Ratsmoker's Avatar
Ratsmoker
I run a 3200 stall converter and it works great. I think it would be a bit sluggish with a stock converter but theres no way for me to tell really. The 801 has a pretty wide power curve. I have busted 2 stock rocker shafts with it though. You will need to get hardened ones. They run about 70 bucks a pop. Its almost crazy not to spend the $600 on the erson setup when you are looking into doing a major upgrade there. It comes ready to bolt on with roller rockers.
Old Oct 17, 2003 | 11:33 PM
gktbay's Avatar
gktbay
If I only had the goodies i used to have ... starting all over again with my 17 yr. old son. Had 2 sets of Harland Sharps, remember them?
Sold all my FE stuff, 2 Torino GT's(68 & 69) and 69 Mercury 428Cj Cyclone back when he was filling diapers.
I appreciate your input --- going to count sheep now ... 'nite.
Old Oct 18, 2003 | 07:34 AM
DuckRyder's Avatar
DuckRyder
I have an 801 with a TCI Sat Night Special converter which is only a few hundred stall over stock.
I think it would work fine with a stock converter. (But again no way for me to really know for sure.)
bracer1963
Oct 19, 2014 10:56 AM
John72_CS
39
Nov 3, 2010 02:20 PM
Lance Hogan
Apr 24, 2010 03:39 PM
flipklos
May 30, 2009 11:50 PM
Charles-65F350
Mar 8, 2001 12:25 PM
