Help Needed if anyone has time.
I acquired a 1967 F100 with a 240 straight six 3.9litre a couple months back. I was told (and continue to be told whenever I contact him ) that the engine is in great shape by the previous owner and that it should run very well.
New parts - Coil, Solenoid, starter motor, fuel pump, plugs, distributor, carb, radiator, and all lines and filter.
I'm at the point where I don't know what else to do and cant spend any more time on it without having anything to go on or some positive outlook. I know we have all been there.
Long story shortened: I rebuilt the original autolite 1100 carb and installed it and got the engine running. Yay!!... nope... For 5 straight days for about 4 hours a day I tried to get it to run right. It would sputter on idle but bog and die when throttle was pressed. I tried to do the timing, vaccuum test was good at 20, new plugs, carb taken off and taken apart at least 15 times watching numerous videos from Mike's carburetor and reading threads from Thunderhead on youtube and this forum. Engine still bogged and dies with throttle depressed. Float, idle mixture adjusting, check weights, needle etc... played with over and over.
I decided to give up and get a carter YF carb from amazon. Linkages line up nice (brand new not rebuilt) and easy to install. Only difference was the automatic choke which I ran a metal line to the choke stove location. I was told by the manufacturer that everything is good to go and adjusted and to just slap it on. Everything fit. The engine ran a little better but not smooth and still boggy and stalls when throttle is given.
I discovered that the crankcase was getting fuel in it with the oil. Big issue so I researched and thought it might be the diaphram in the pump leaking gas past down into the oil. I was also told that this could be the reason it was bogging and dieing and not running right. New fuel pump and same old thing and i'm pretty sure I'm still getting some gas in the oil. Oil was changed with new oil and filter. Previous owner is adamant that its not the rings leaking fuel down past the cylinders. Compression is good too.
I took apart the whole exhaust thinking something might be clogged by mice or something right up to the manifold on the block. Clean as whistle now.
I took the fuel tank off and cleaned all the lines and tank.
I tired a little 4-7 psi electric fuel pump out of frustration and the engine actually ran pretty good and responsive to throttle a bit (way smoother than before but still not great) but after further research, I discovered that without an oil pressure switch and mounting the pump near the tank, this can be dangerous. So I would like to stick with the new mechanical pump. Engine runs horrible and bogs and dies.
I sprayed carb cleaner all around the base of the carb and no vaccuum issues.
Can anyone help me. I am at my end.
I guess this truck had been sitting for some time, you did not hear it run or a test drive before you got it to know for sure what the other guy is saying is true or not?
Did you do a compression test or took the owners word the rings & compression is good? Post up the numbers. Also a picture of the plugs.
Do you have a dwell meter / tach and timing light? If not you will need them.
Being it runs with the fuel pump on the motor and you want to use it for safety
lets get that hooked back up.Recheck the firing order 1-5-3-6-2-4
Have you replaced the points & condenser yet? This could be why it will not run and might be a good time to replace them as everything else has been to this point.
When you get it idling again hook up the meter and post up what the dwell is, you will need to look up the spec as I don't know what this is.
Once the dwell is set to spec you can check the timing and set it after the idle speed is set.
As a guess the dwell is off and this will throw off the timing.
Oh that new carb will need to be tweaked to run 100% but should be good enough out of the box to get the motor up to temp before tweaking.
So with the dwell, idle speed, timing set and motor up to temp recheck the idle speed.
With a vacuum gauge hooked up you can adjust the idle mixture screw to get the highest vacuum reading.
That should cover about everything so it should run pretty good and if not let us know what is going on.
Dave ----
https://www.ford-trucks.com/forums/1...x-ignitor.html
Dave ----
And, have to ask, how old is the gas in this thing? You had the tank out and cleaned everything up so I'm hoping that it has fresh clean gas.
https://www.cargurus.com/Cars/Discus...13903_ds918960
Took off the 1 and 6 plug and checked for spark. Nothing. Took out a volt meter and have power to coil and distributor cap.
Where can I go from here?
Do you think a faulty distributor was the cause of rough running all along. When the engine idled it was rough to begin with and shook terribly. I thought it was flooding but now I'm wondering if it was a misfire on a few cylinders. (if thats possible) Condensers are super expensive up here (40 bucks and above, crazy I know) I wonder if its better just to order a new HEI distributor? Or can I do anything before that to make sure thats the problem??
Thanks so much for the help!
Pop the cap off and rotor so you can see the points.
You want to turn the motor, by hand if you can, and set the points rub block on a high point of the dist. lobe where they are open.
Now I don't know what the gap should be but after checking to make sure the contacts are in good shape, no high or pits, you can take a match book cover and slip it between the contacts.
It should just drag a little and the 2 contacts should not be pushed open or close when you remove the book cover.
When that done see if you get spark. If not it could be the condenser.
BTW if you put a test light on the neg. side of the coil where the points wire is hooked to, when you crank the motor or open and close (points have to be on a low side of the lob) you should see the light flash and get a spark.
No flash = no spark it is that simple.
And yes if the points were starting to close up, loose screw, that would make it run not so good.
Dave ----
I've been bending wrenches and breaking stuff since I was a little kid and even routine maintenance jobs, I like to refresh myself with the manual. Ford literally wrote the book on this stuff. I usually learn something I didn't know before. Just because I've been doing something for a long time, doesn't mean I've been doing it correctly. Between the shop manuals, websites, and forums like FTE, has really saved my bacon more than once. Feel a lot more confident tackling stuff.
If the distributor has turned for some reason the coil may be firing in between two cylinders - either way to far advanced or retarded. Turn the engine by hand and stop where the points just start to open. Look at the position of the rotor and compare it to the posts on the distributor.
Check the carbon button as mentioned. I like to take the wires off (one at a time is probably safest) and polish the brass wire ends shiny bright, and polish the distributor cap receptacles, then spread the connectors out a bit as required, see to it that the wire end terminals are fully seated with a tight interference fit. A smear of dielectric grease on the inside of the boots keeps moisture away. Good solid electrical contact is very important. Kerosene or WD40 is excellent to keep grime and crud off the wires insulation.
