Battery completely dead
Old Jun 5, 2020 | 09:08 PM
super_duty_532's Avatar
super_duty_532
Haven't driven the truck much for the past few months. So couple days ago I went out to wash the truck and found it wouldn't even unlock with the key fob.. the battery is very dead. I pulled out the multi-meter and it measured about 2 V. I have a NOCO Boost GB150 4000A battery starter and thought it should be piece of cake to get the truck started. Nope. I guess it wouldn't work with the voltage being this low? I gave up and then ordered a noco genius 2 battery charger. After a couple of hours of charging, truck finally started with the battery starter. It was such a pain. I probably won't use the truck often in the near future so I'm thinking to leave the battery charger connected 24/7. The thing is the truck is parked outside so it's not very neat to keep an extension cord connected to the engine bay. Is there a better solution?
Old Jun 5, 2020 | 09:12 PM
ford390gashog's Avatar
ford390gashog
Did you press the boost button when trying to jump it? If a cord is out of the question and you don't drive it often take the batteries out and leave them on a float charger. Your current batteries are probably no good, they can't be taken to that low of a voltage without damage.
Old Jun 5, 2020 | 09:18 PM
Mattm400's Avatar
Mattm400
If it sits for any legnth of time I would definitely put a battery tender on it. With All the electronics these trucks have, I'm sure they are using small amounts even while sitting.
mine sits in the garage through winter & I keep a tender on it if its longer than a week.
Old Jun 5, 2020 | 10:45 PM
super_duty_532
Yeah I need to get it tested. Truck is only 2 years old.. is battery still under factory warranty if it's bad?
Old Jun 5, 2020 | 11:26 PM
TTXDavid's Avatar
TTXDavid
https://www.pulsetech.net/store/sola...-chargers.html
Old Jun 6, 2020 | 05:31 AM
seville009's Avatar
seville009
Rather than keeping the charger/tender on it, another option if you don’t use the truck for long periods of time is to just disconnect the battery
As was mentioned above, it is certainly possible that your battery on its last legs anyway (is it the original?)
Old Jun 6, 2020 | 08:44 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
They have those small Solar trickle chargers, you keep it inside the windshield. I heard it works very well.
Old Jun 6, 2020 | 01:46 PM
super_duty_532
Disconnecting it is a good idea. I will fully charge it, disconnect it, then wait for a couple days to measure voltage. If it's dead again, then it should be bad for sure. Yes it is from the factory. Only 2 years old.
Old Jun 6, 2020 | 07:58 PM
felixtruck101's Avatar
felixtruck101
I have a 2019 and was told by my mechanic that they draw and I should start or have a tender, he gives it 7-days or die. This is bad as I don't use it as a daily driver.
Old Jun 7, 2020 | 02:41 AM
seville009's Avatar
seville009
Your mechanic is wrong; maybe he was referring the Fords going into “sleep mode” after a certain period of time (which is to actually prolong the battery life)
Old Jun 7, 2020 | 04:55 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
A 2 year old truck and you don't drive it for months at a time? Why not?
You could just disconnect the battery from the truck. Throw a battery tender on it once a month for a day or two. This is what I do with my trailer winch battery that lives in my garage until I need it. It would solve your extension cord issue.
Or drive it once a week...
Old Jun 7, 2020 | 06:08 AM
System's Avatar
System
Prolocutor
OP, if your truck is under 36k miles then yes, the battery is still under warranty. Your dealer will swap it out for free. After that, I second the idea of a solar battery maintainer if your averse to an extension cord....
Old Jun 7, 2020 | 07:42 AM
C12H24's Avatar
C12H24
You don't need to run household current out to a battery tender. I use a 20' extension cord that plugs into the tender's charge cable. The tenders stay under cover in the garage and the charge cable runs out to the vehicles.
Old Jun 7, 2020 | 09:11 AM
Desert Don's Avatar
Desert Don
Another vote for a solar powered battery MAINTAINER; not battery charger. The maintainer will go into float mode when the battery is fully charged, where a charger will overcharge your battery. the maintainer, you hook it up and forget it.
TexanAmmo
33
Aug 27, 2016 07:20 PM
crazy96863
Jul 8, 2014 12:36 AM
evobuilder
Oct 5, 2012 06:24 AM
aurgathor
Electrical Systems/Wiring
Jan 29, 2005 12:50 PM
RyanMiller
Oct 16, 2004 05:09 PM
