Cannot recommend Dynatrac Ball Joints
Old Jun 4, 2020 | 07:18 PM
6_Myles's Avatar
6_Myles
While it is a great product and I have received amazing customer service from them, and 10 years of service from the ball joints....I have been trying for 2 days to 'rebuild' them and have managed to get one single ball joint replaced. They are not worth the effort required to disassemble and reassemble; I could have pressed in and out 10 sets of normal ball joints in the time that I have been messing with these things.
Admittedly, I'm frustrated as all get out after 2 days of trying to make these work and spending a ton of money on the initial system, money on the rebuild kit, and then another full lower ball joint because the c-clip was frozen in the cup and can't be disassembled, I'm about a grand into these, which is not a great feeling.
Your mileage may vary, but this is my experience.
Old Jun 5, 2020 | 07:18 AM
6_Myles's Avatar
6_Myles
Well, clearly i was having an emotional reaction last night....lol...and I’ll leave the post as historic record of my meltdown.
After sleeping on it I decided to give it another go this morning, but using my ball joint press In some different ways instead of hammering away at them more. the shaft and new bearings slid right in, no problem...so while they say you can install these without a press...my experience says that it helps tremendously
So....i will put these other ones in and see how it goes and report back but I am still of the opinion that these can’t be installed trial side
Old Jun 5, 2020 | 07:21 AM
DavenTn's Avatar
DavenTn
How many miles before the rebuild was necessary?
Old Jun 5, 2020 | 07:25 AM
6_Myles's Avatar
6_Myles
A. Lot.
Probably around 125k miles.
Old Jun 5, 2020 | 07:38 AM
DavenTn's Avatar
DavenTn
My OEM got 150K before I replaced them.
Old Jun 5, 2020 | 07:50 AM
6_Myles's Avatar
6_Myles
I had 75k on my factory ones when I got the excursion. They lasted another 25k before they needed to be replaced. 35’s and running around logging roads a decent amount really beats up on them. And truthfully, there wasn’t any slop in these joints I just was having really hard steering and had replaced everything but these and figured for the rebuild price, it was worth it to try before going the steering box route.
I bought into the Dynatrac system because of the ‘ease’ of rebuild, especially when/if they failed on a trip. THey are a great piece of precision manufacturing but I’m not 100% sure i could recommend these over OEM or Moog In either the longevity or the ‘replacement’ category.
The build kit was only $200 (less than buying new BJ’s all around) so I figured it was worth it. Had I gotten Moog’s at Oreilly’s with a lifetime warranty, I would not have had to spend a dime and the amount of work would have been the same.
Hopefully I’ll remember this thread when/if it becomes replacement time again in 10years.
Old Jun 5, 2020 | 04:17 PM
6_Myles's Avatar
6_Myles
Update, I have everything assembled. Once I started using the press to get the studs and bearings back in, it went very smooth...and that is the rub....if I'm gonna have to breakout my balljoint press, I might as well press out the whole unit and not have to do any of the other work. And no way this is going to get done trailside.
Final conclusion, unless you are plowing or running 37+" tires...there's no desernable value to these over other, much cheaper, options.
BigBlueX
May 9, 2016 05:04 PM
autoxtech
Dec 11, 2010 07:15 AM
rbsample
35
Dec 10, 2010 06:55 PM
crashed13
Feb 23, 2006 02:28 AM
Rackpatrol
May 11, 2004 09:27 PM
