Remote Access replacement
Old Jun 4, 2020 | 05:03 PM
Xwild's Avatar
Xwild
Got an email that Remote Access ends Dec 31, 2020 due to AT&T discontinuing 3G service.
Anyone know of an equivalent for 2017 trucks?
Old Jun 4, 2020 | 08:59 PM
NorEasterMA's Avatar
NorEasterMA
I haven't heard of this, but I'd be pretty upset about it considering I just re-upped my annual subscription. I'd like to know of a good replacement for this too - I've gotten so used to the ability to start from my phone I wouldn't definitely miss it.
Old Jun 4, 2020 | 09:14 PM
Ding126's Avatar
Ding126
hopefully 3G is cancelled because of going to 4 & 5G
Old Jun 5, 2020 | 05:43 AM
BGMSPD's Avatar
BGMSPD
I got the same email yesterday and was due for my renewal on 7/1/2020 which they prorated. Only cost me $20.00 for the rest of the year.
Site says people who paid for subscription past December 2020 will get refund.
Old Jun 5, 2020 | 01:02 PM
NorEasterMA
So I guess the big question now - what do the rest of us do? For me, I had installed the FT4Z/RMU unit as many did, but after my low quality 12volt.solutions unit failed, I did not have key-fob based remote start, only phone based. Since the FT4Z is just a VSS module, it won't start the truck. So I've ordered the JS7Z/KN1Z VSS+ remote start module that a ton of guys on here use and when we get closer to the end of the year, I'll pull the old VSS/RMU out of the truck and replace it with the new VSS so at least I can start my truck with my key fob. Damn, am I ever cursing myself for buying a truck without factory remote start. What was I thinking!! Real question is, instead of the new VSS, should I just buy a new truck instead?
Old Jun 5, 2020 | 03:14 PM
GABAR's Avatar
GABAR
Interesting problem you have.
A new truck is always nice but a much cheaper solution would be to rake a look at the aftermarket.
I think Viper might have something that’ll help you out.
Old Jun 5, 2020 | 03:50 PM
Xwild's Avatar
Xwild
The email showed up in my spam yesterday. Here it is for those of you that either didn't get it, or missed it.
Dear Valued Customer,We are writing to inform you that due to the upcoming discontinuation of the AT&T 3G network, all Ford and Lincoln Remote Access subscriptions will conclude on December 31, 2020.
You may or may not be aware, cellular network connectivity is required to operate your Ford or Lincoln Remote Access system, and unfortunately, AT&T is in the process of decommissioning the 3G network upon which the system relies.
If your current annual subscription period would have extended into 2021, please be aware it will cease to function on December 31, 2020. For customers who previously renewed on or after January 1, 2020, you will be able to request a prorated refund for the unused balance of your subscription cost. If you are currently enrolled in an automatic renewal program, or actively choose to renew during the balance of this year, we have discounted the renewal rate for the remaining calendar year.
We appreciate and value you as a customer. While we regret any inconvenience this announcement may cause, we suggest you please contact your Ford or Lincoln Dealer for possible alternatives.
For more information regarding the subscription fee, please contact 1-800-FORDKEY.
Old Jun 5, 2020 | 03:52 PM
Xwild's Avatar
Xwild
I'm voting that you need to just get a new truck.
Old Jun 5, 2020 | 03:53 PM
Xwild's Avatar
Xwild
I'm definitely going to be looking for a solution. I use the cell start all the time in the winter so I can start it from my office at the end of the day.
Old Jun 5, 2020 | 04:52 PM
NorEasterMA
GABAR - I'm hesitant on the VIPER product because it appears to include a new fob in addition to the smartphone app, I really do not want to stray from the OEM flip keyfob. It's likely I have not researched enough but that was my preliminary findings. I really like the plug and play aspect of the Ford VSS versus aftermarket/splicing wires.
XWild - I do the same, though I can use the fob from the window easily, which is clearly what will ultimately happen as I transition to a fob-based start versus smartphone. If you find anything truly comparable post it up!!
Old Jun 5, 2020 | 05:02 PM
jollyrogr's Avatar
jollyrogr
What trucks are affected by this?
Old Jun 5, 2020 | 08:30 PM
Xwild's Avatar
Xwild
Any that the owner had the Remote Access installed on. A bunch of us with the 2017s did so, as it gave us Cell Phone based Lock/Unlock/Remote Start. Nowadays FordPass has that built in I think.
And the Smartlink module offered it I believe, but I believe that has already been discontinued?
Old Jun 5, 2020 | 09:00 PM
adamsfbay's Avatar
adamsfbay
I have the viper system. 2018 F-250 limited. Works with original fob. App is solid. Lock unlock start stop gps and security alerts. Can ping for truck status: fuel battery voltage hood/doors open/closed/locked etc. Also real-time alerts for truck start stop movement etc. Is faster and more responsive than my old Ford SmartLink
Old Jun 5, 2020 | 09:58 PM
morleyz's Avatar
morleyz
My 2017 remote access was due for renewal in November 19 and they wouldn't let me renew because of this. Stopped working on the day after expiration. Chicago winters are cold and I really wanted the long distance remote start. Ended up buying a Fortin evo-fort3 and Audiovox ASCL6. Plug and play T adapter behind the OBD port besides needing 12V power. Easy install, but not the cheapest.
Old Jun 6, 2020 | 07:15 AM
NorEasterMA
Could you give me some more info on what system you have and how the install was (if you did it). It sounds really good on paper. I do want to retail factory fob use and would like the app based data too. I hate the idea of having to cut and splice for the install, but I'm curious none the less. Thanks!
