question is , is there a hot key or bottom that turns the display off from out side of the sync 3 software? I know I can go into the software and turn the display off.
i checked my console and steering wheel and no display off button is evident.
sometimes my display goes off, I can turn on the camera and see the camera display, but I don’t see a butterfly n to reactivate the sync 3 display.
Your post is a little confusing. But what I think you want to know is, is there an On/Off button for the Sync system (radio, etc.). Correct? If so, there is not one that I am aware of. When my screen locked up once, I had to shut the truck off completely. I let it sit for a minute or two, and started it back up, and all was well. But, a little clarity would help.
I’ve looked into it. There is no “hot key” to turn the screen off. I wish there was. Driving straight through the night, that screen gets bright, even on the lowest setting.
There is a way to do a master reset on the screen but I’ve never had to do it. Locked up on me once and worked fine after cycling the truck.
It’s not you doing anything spearkerfritz. There’s no combos of buttons you can hit to turn the screen off. Like you said, you have to go into the sync screen.
