37 spare tire?
Old Jun 2, 2020 | 09:15 AM
302help's Avatar
302help
37 spare tire?
Can you fit a 37 as the spare tire in the stock location?
Old Jun 2, 2020 | 09:41 AM
TX Crawler's Avatar
TX Crawler
Nope. Not unless you wanna opt for the Carli hitch.
Old Jun 2, 2020 | 01:02 PM
302help's Avatar
302help
That stinks.. Are you guys with 37's leaving a spare in the bed? Is there an issue with using your regular size spare with 37s?
Old Jun 2, 2020 | 01:09 PM
Mainebucks's Avatar
Mainebucks
When I went to 37"s I bought 5 tires and rims. One stays in the bed cable locked. You can use the spare in a 5 tire rotation.
I don't want to be on vacation or in the wilds of Maine and then trying to drive home on 3, 37" tires and 1, 35 lol. It might take a week or more to get another 37 inch tire in. If you are just using the truck locally then you could get by with a smaller spare.
Old Jun 2, 2020 | 01:30 PM
4Seams's Avatar
4Seams
If just making do with a smaller spare, does it matter if the smaller spare gets put on front or back? If you got a flat on a rear tire, would it be best to put the spare on a front, and move the full-size front to the rear so that the rear axles and diff aren't spinning at different speeds? Assuming you're staying out of 4wd of course.
Old Jun 2, 2020 | 01:46 PM
TeddyD's Avatar
TeddyD
It matters if you have a limited slip or open differential. If you have a limited slip, smaller spare goes on the front. For an open diff, it doesn’t matter. Just don’t engage 4 wheel drive in either situation if on high traction ground.
I don’t have 37s but I do have factory size tires on 20” rims. The spare tire on my truck was undersized by about an inch in diameter. I have a few sets of extra tires so I just bought a random cheap new 20” aftermarket wheel to mount one of the extra stock size tires on. I had to do this because if I get a flat, I’m so remote that getting a new same sized tire may takes weeks and I need 4x4 daily.
Old Jun 2, 2020 | 01:52 PM
Stinson1's Avatar
Stinson1
How about a deflated 37” spare in the stock location. This could be an option possibility for people with on board air.
Old Jun 2, 2020 | 01:56 PM
Mainebucks's Avatar
Mainebucks
Good idea! If it would fit.
Old Jun 2, 2020 | 03:22 PM
Texas78028's Avatar
Texas78028
There are some newer vehicles these days that don't even come with a spare tire. They give you a plug kit and air compressor instead.
Old Jun 3, 2020 | 12:45 AM
digz's Avatar
digz
that looks bad ***!
Old Jun 3, 2020 | 01:09 PM
TX Crawler's Avatar
TX Crawler
Originally Posted by digz
that looks bad ***!
It ought to for $2,000. I've got less than $180 in mine and that included the strap from Mac's.
Old Jun 3, 2020 | 01:17 PM
Mainebucks's Avatar
Mainebucks
My tire just lays in the back. Cable locked to the 5th wheel rail.
Old Jun 6, 2020 | 09:16 AM
Ding126's Avatar
Ding126
I stowed a 37 x 12.5 x 22 spare tire in the stock location on my 2008. I did have to remove the heat shield. Didn't have any issues with the tail pipe being 2-3 inches away
Old Jun 16, 2020 | 07:47 PM
speakerfritz's Avatar
speakerfritz
this is what I was thinking...
FordGirl!
18
Apr 4, 2020 05:03 PM
Cobwebman
Mar 30, 2020 11:39 AM
2017-350
Feb 26, 2020 07:14 PM
wbuffetjr1
May 16, 2011 08:32 AM
Stephen
2004 - 2008 F150
Jun 6, 2004 02:42 PM
