You haven't finished cleaning out the garage but actively selling the place? Or did you move everything out and now going through it somewhere else?
No reason the house and garage needed to be completely empty to sell.
Originally Posted by HP junkie
Good morning fellas!
Yay! Another day of social unrest in St. Cloud. 36 arrested last night for looting and for what? What does looting prove for your protest? I am starting to despise social media.
All due to false information about the police shooting two black men when in fact it was a black man that shot a policeman. Yikes! People are stupid!
On another note: Happy Tuesday!
And we have a signed purchase agreement now on moms place. Closing on July 17th.
Good morning Jim!
Good morning Cory!
What a mess! Not good.
Good evening guys. Dang deer mowed down a bunch of our plants last night and this morning. Grrr! Just put some fencing around them tonight. Some were just About to bloom too.
So I need some helpful suggestions. Some neighborhood cat has been spraying our front door at night once in a while. What can I realistically do to scare it off. All suggestions other than shooting it will be considered.
Deer should taste good this fall
Which neighbor is it? Could you trap it and release it a few miles away?
Worked on the pickup again after work yesterday. I replaced the y pipe that I think we broke when removing the engine and now I'm having trouble getting the turbo flange to seal. The new y pipe is a lot stiffer than the hold one. I left the bolts loose and then installed the turbo and clamped it down. I think I probably need to remove the up-pipe to manifold bolts completely, get it seated and then try and get the bolts back into the manifolds. Truck feels better now but there is a pretty good leak when you get on the throttle still. I might swing by home depot and pick up the parts to build a boost leak tester and make sure the charge pipes and intercooler isn't leaking too.
That sucks!
Hmmmm don't know what to tell ya. Electric fencer hooked to the door maybe........
Good morning folks.
Good morning Jay!
Yeah those new uppipes can be a bit stiff. Usually when I do them I just leave the manifold bolts loose and hook up the turbo and bolt all that tight and do the manifolds last. A boost leak detector at this point would probably be a good thing.
I have no idea who's cat it is. Only seen it around a couple times.
That sucks Chris. Not sure what size you need for the boost leak tester but I do have one if you want to use it.
Originally Posted by fordpower88
That sucks!
Good morning Jay!
