Headlamp assembly upgrade
Old May 31, 2020 | 06:59 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
My drivers side headlamp assembly has a bit of condensation building up. I've read where these headlamps are vented and the condensation can be removed.
If I end up changing out my headlamps, I'm looking for suggestions / recommendations on replacements. The truck is an XLT with the standard headlamp assembly, not HID.
The OE headlamps from TASCA are running about $250.00 each side which is likely less than half what the dealer would want.
I don't know a lot about other options or trusted sources but many of you on here are mod gurus so I'll defer to your expertise.
Old May 31, 2020 | 12:52 PM
Siberexpress's Avatar
Siberexpress
Here is a set of the Raptor or FX Halogen headlamps for $290 for the set from a Ford dealer. I found out a long time ago to go with OEM replacements on Head and tail lights.
Juanito
Aug 19, 2020 07:17 AM
YouDon'tKnowMe
Feb 7, 2017 10:56 AM
DaNg3r0u5p3nGu1n
Mar 21, 2013 04:56 PM
finneys98xj
45
Aug 3, 2012 11:50 PM
JonathanN
Sep 6, 2010 01:26 PM
