Trying to make sure the valves are set right on my engine, the book says I need a
Ford Hydraulic Lifter Leak Down Valve Lash Adjustment Tool T58P-6565A
https://picclick.com/Ford-Vintage-Hydraulic-Lifter-Leak-Down-Valve-Lash-222416602870.html
Which of course I can't find, does anyone have any tricks or ways to get the lifters to leak down so I can check the clearences? We've tried to come up with a tool to do it but are having a hard time figuring one out. If anyone has any ideas on subsitutes etc that'd be amazing. I had the valve guides redone and don't know if it was in tolerance when I started work on the engine so I really I would think do need to make sure it's right before putting it all back together.
THanks
When I done my 330HD FT I managed to collapse several. Checked lash then checked push rod length and found most to long so ordered set all same length. Have one that ticks off and on.
