Pedal Position sensor? PCM?
Old May 28, 2020 | 01:26 PM
mzwizanski's Avatar
mzwizanski
96 F250 7.3, Just finished with a cab swap, all wiring was moved over, trans was rebuild. Took it for a drive seemed fine, ran good, but lacked power on hills. Flat ground seems ok and downhill it seems fine but definitely the low power is noticeable on a hill. Got it home and hooked up Auto Enginuity, Accelerator position sensor is showing 76.8% when pressed all the way down. I am assuming it should read 100. Thought it may be the floor mat in the way, unbolted it and press it all the way only 76%. I also had a P0603 code but I had the batteries out for weeks, and just put new ones in that day. Does this sound like a pedal position sensor issue? Or could it be something in the PCM?
LCA078
Mar 9, 2020 07:39 PM
mossyoak.miss
Aug 11, 2015 09:54 PM
PJ-Hunter
Oct 22, 2010 07:21 PM
