Acceleration Delay Problem
Old Jul 31, 2015 | 10:18 PM
mossyoak.miss's Avatar
mossyoak.miss
Alright I have a 96 f250 7.3L manual. I'm having a problem figuring out what is causing a check engine light to come on when I accelerate. Any ideas to what it may be and what could fix the problem?
Old Aug 1, 2015 | 04:52 AM
427 fordman's Avatar
427 fordman
Welcome to fte. No real way to know without the code. Parts store readers won't read our trucks either. What exactly is happening/wrong?
Old Aug 1, 2015 | 08:05 AM
mossyoak.miss
Its bogging down then takes off, with high rpm. I got a Po122 code to read once. It points to the PCM, IVS, water in the fuel, TBS or APP. I've replaced the sensor on the pedal. That didn't help. Any ideas?
Old Aug 9, 2015 | 06:23 PM
IDMooseMan's Avatar
IDMooseMan
Is that the only code showing up at this time? P0122 is an "Accelerator Pedal Sensor Circuit Low Input" code. Sounds like you replaced that sensor.
Does the tab on the pedal assembly completely depress the button on the sensor when you release the accelerator pedal? Do you hear the "click" as you begin pressing the accelerator pedal?
You can bend the tab so the slightest pedal movement activates/deactivates the sensor. Unless other codes are stored, I don't know what else to suggest.
Old Aug 9, 2015 | 06:26 PM
Action4478's Avatar
Action4478
Did you replace the TPS or the IVS ?
Old Aug 9, 2015 | 07:18 PM
oldbird1965's Avatar
oldbird1965
If its bogging then its not the IVS. It will only idle it that is bad. Sounds like a engine problem.
Old Aug 9, 2015 | 07:54 PM
Action4478's Avatar
Action4478
I'm trying find out what the OP did & what is actually happening . His original description with the code can be either .
Old Aug 11, 2015 | 10:06 AM
madpogue's Avatar
madpogue
Whatever device you're using to obtain the codes, does it also read live data? Can you set it up to read APS (aka TPS) voltage as you move the pedal from idle position to the floor? You can do this key on / engine off.
Old Aug 11, 2015 | 09:54 PM
Action4478's Avatar
Action4478
You can also read it with a volt / Ohm meter if you don't have a scanner .
defyrftr
Feb 22, 2014 06:25 PM
nickt916
15
Nov 30, 2013 05:15 AM
2000 roadking
Nov 2, 2009 12:44 AM
