Trailer disconnect message
Old May 28, 2020 | 11:06 AM
Spantier's Avatar
Spantier
Everytime I hit the brake I get the trailer disconnected message. Once I let off the brakes it says reconnected. I also can't actuate the brakes manually. Not sure if it's a ground issue, brake controller issue, or wiring issue. Any ideas?
Old May 28, 2020 | 11:24 AM
ford390gashog's Avatar
ford390gashog
Normally its a trailer ground issue. Is your trailer actually grounded through the 7 pin? I have seen plenty of trailers that the only ground was the hitch which isn't correct.
Old May 28, 2020 | 12:44 PM
crewzer's Avatar
crewzer
Sounds like the brake wiring circuit has a break somewhere. Check fuse for the brake controller, the wiring from the truck to the brakes, and the brake common wiring.
HTH,
Jim / crewzer
Old May 28, 2020 | 04:24 PM
RV_Tech's Avatar
RV_Tech
First simple steps. #1 that a jumper cable and connect the trailer frame to the frame of your truck. If the problem goes away, you have a grounding issue. #2 Make sure the seven pin plug on your truck is clean and the connection is good. As a general rule, the brake controller is the least likely problem as is the wiring, other than at the connections.
Steve
jaygee15
2015 - 2020 F150
Dec 28, 2017 03:12 PM
Eric Ahl
All Things Towing
25
May 28, 2017 07:06 PM
jsmithis101
2004 - 2008 F150
May 7, 2012 08:42 PM
Bronsonh
Apr 27, 2009 10:55 PM
jefftb
All Things Towing
Aug 5, 2008 11:27 PM
